gas cap install - Ducati.ms - The Ultimate Ducati Forum
SportbikeTrackGearMotorcycle.comGraves Motorsports
Old Aug 20th, 2008, 10:00 am   #1 (permalink)
gas cap install
so i removed my gas cap to seal a dreaded leak. anyways, can't get the cap back on - the upper seal won't slip into the tank groove... i seem to remember a trick with rolling the upper rubber gasket down or folding it over or something - can someone refresh me?
stainlesscycle is offline   Reply With Quote
Old Aug 20th, 2008, 12:38 pm   #2 (permalink)
i figured it out...
Old Aug 20th, 2008, 12:51 pm   #3 (permalink)
SussexDuke900's Avatar
Images: 2
how do you do it then?
first time Ducati Owner. O yeah I am an addict now.
2002 900 fully faired Sport, kn crankcase breather, Kn with snorkels removed
Magnecor leads, Standard Copper Plugs (moved off the iriduim ones upon advice), Gillies Variobar clip ons
Carbon Clutch Cover (soon to be replaced with custom alloy one so many to chose from), Uprated stainless springs and alloy pressure plate.
Battery tender (a must), 14-bs battery, gearing is now 14t to 40t all alloy renthal
Projects in the pipe lines
Too many to mention
SussexDuke900 is offline   Reply With Quote
Old Aug 20th, 2008, 1:56 pm   #4 (permalink)
silas's Avatar
how did you seal your tank? I'd like to do mine too but am hesitant to do the long POR-15 process.
thanks.
duck/goose fan
silas is offline   Reply With Quote
Old Aug 20th, 2008, 2:57 pm   #5 (permalink)
sealed tank with caswell tank sealer. i've done about 8 tanks with it. it works better than any other product i've tried. cures in 24 hours. easiest product to use also.
as for installing the cap:
remove upper rubber ring completely. lube green o-ring. install cap 95% (maybe 2-3mm showing). stretch upper gasket over cap, and slowly work it down in - the last 1" or so takes the longest. it will go. total time almost 15 minutes (which feels like forever when you're working with just a little rubber gasket...) but it works.
Old Sep 21st, 2008, 6:26 pm   #6 (permalink)
How did you put the gasket back on
How did you do it ?!?!?! I am in the garage and looking at this like a monkey and cant figure how to fit that thing in !!! Please help !!
2002 M620 Dark (gone)
2005 749 Bip Red
Ducati is for Yamaha what Sashimi is for Sushi. Give me the meat hold the rice.
migrane is offline   Reply With Quote
Old Sep 21st, 2008, 6:30 pm   #7 (permalink)
ikan's Avatar
you would wrap the sealer around cap then just its just the screws. thats how mine fitted.
ikan is offline   Reply With Quote
Old Sep 21st, 2008, 6:30 pm   #8 (permalink)
Forgot to mention
This is on a SS800 ...
Please help
thanks
2005 749 Bip Red
Old Sep 21st, 2008, 9:46 pm   #9 (permalink)
remove upper rubber ring completely. (this is the problem top o-ring/top seal)
lube upper rubber ring.
install metal cap 95% (maybe 2-3mm showing) without the upper rubber ring on it..
stretch upper rubber ring over cap, and slowly work it down in/under the metal cap - the last 1" or so takes the longest.
it will go.
Gas Cap dh1100 HyperMotard 10 Sep 12th, 2008 12:05 am
I Installed a New Gas Filler Cap joeychitwood Sport Touring 10 Jun 17th, 2008 7:40 am
Gas cap tech help race2win1 HyperMotard 1 May 9th, 2008 1:10 am
Black billet gas cap on a Black Monoposto wasp1000 Sport Classic 13 Mar 30th, 2008 11:29 pm
