Gas experiences? - Ducati.ms - The Ultimate Ducati Forum
Graves MotorsportsSportbikeTrackGearMotorcycle.com
Old Jul 20th, 2007, 12:30 am   #1 (permalink)
fawkes's Avatar
Gas experiences?
I just hit 600 miles and happened to grab the mid grade gas instead of regular on accident. The bike reacted completely differently. At low gear it felt smoother and I am also wondring if it was more quiet. Is this a figment of my imagination or has anyone else noticed differences in how supersport handled with various grades of gas? What about gas milege? My slow speed turns were even tighter I think but maybe it's all in my head or something.
A girl named Maya and her Fawkes
'07 800SS
fawkes is offline   Reply With Quote
Old Jul 20th, 2007, 12:53 am   #2 (permalink)
Images: 40
Yeah, it's probably in your head...
A stock compression SS does not "need" premium.
..but don't let me change your mind,
save the 10-20 cents per gallon,
...and enjoy the increased performance!
RichD is offline   Reply With Quote
Old Jul 20th, 2007, 1:06 am   #3 (permalink)
I have terrible gas after eating broccoli
Seriously:
Higher grade gasoline has more detergents, and higher octane. The higher octane prevents pre-detonation(ping/knock), mine sputters a little on regular grade gas(98 900SS),but not constantly, so I don't sweat it. Even with Premium gas the bike is cheaper to run than my SUV.
DucatiDom is offline   Reply With Quote
Old Jul 20th, 2007, 1:26 am   #4 (permalink)
Mike's Avatar
He never mentioned premium, he said it runs better on mid-grade.
The manual recommends AT LEAST 95 octane which means higher than 90 octane in the states. Plus, the OP already said it runs better on mid-grade, not surprising since the fuel and ignition map is tailored to the higher octane. I say run whatever it runs best on, don't worry about the extra $15 or so more it might cost you every year. You want the best riding experience you can get.
Mike Mullen
2002 STealTH Ducati ST4s (x2)
1985 Ducati Mille S2
Mike is offline   Reply With Quote
Old Jul 20th, 2007, 1:56 am   #5 (permalink)
fawkes's Avatar
Okay, so it wasn't just in my head! I always put regular in the tank because my last bike took it and I was shocked at the difference when I put the midgrade in it. First gear wasn't near as flippen choppy. I'm going to try both again and check the speed vs. rpms because it felt like it wasn't reving so hard either. More research is definitly in order. Thanks for the tip about the manual I looked for gas requirements but must have overlooked it.
'07 800SS
Old Jul 20th, 2007, 2:04 am   #6 (permalink)
redpato's Avatar
I will normally run regular grade. But on the occasion I've used premium I find mine runs smoother and gets a tad better fuel milage.
"in accordance with the prophecy"
"in God we trust"
1996 900 SS/SP #C25
redpato is offline   Reply With Quote
Old Jul 20th, 2007, 7:50 am   #7 (permalink)
It also depends who's gas it is. Some blends perform better than others. You may find a little more octane helps during hot summer riding on air cooled engines. I'd stay away from the generic no-name brand fuels and I hate using Citgo, but either is better than pushing.
I find a little Beano on the anchovy/guacamole/egg and spicy sausage pizza helps cut down on gas distribution issues .....
'05 ST3
'90 906 Paso
It's not just a Ducati, it's a disease!
jack is offline   Reply With Quote
Old Jul 20th, 2007, 8:05 am   #8 (permalink)
racerboy's Avatar
Images: 2
That's interesteing. I just switched over to running Shell regular grade in my 900CR (all stock except for a jet kit) and found the bike runs smoother and have been getting 50+ MPG. I was running no-name premium before that and never got that kind of mileage.
2009 MTS 1100S
2008 1098R #041
1992 900 SS
racerboy is offline   Reply With Quote
Old Jul 20th, 2007, 8:11 am   #9 (permalink)
The manual recommends AT LEAST 95 octane which means higher than 90 octane in the states. .
"the manual" don't ride. Screw the manual. Half the info in there is wrong (break in among it). You don't need high test w/ stock engine.
xseal is offline   Reply With Quote
Old Jul 20th, 2007, 8:19 am   #10 (permalink)
supersparky750's Avatar
I get better mileage and smoother running with mid-grade than with regular or premium. When I tried running premium for a couple of tanks I figured I'd probably see no difference, but actually lost a couple of miles a gallon.
Andy
'99 750ss - dp high mounts, open air box, 996 forks(.85 springs and GP suspension valves),
Penske shock, 14-42 gearing, '02 alloy swingarm
And a whole pile of bits I may never have time to put on
supersparky750 is offline   Reply With Quote
Crash experiences? ajaxajax2000 Sport Classic 27 Aug 20th, 2007 12:15 pm
Arizona (Phoenix) Dealer Experiences gunnerguate Superbikes 28 Jun 6th, 2007 10:54 pm
Insurance Experiences redduc59 Ducati Motorcycle Chat 31 Feb 25th, 2007 12:36 pm
Please share your dealer experiences japhar81 Ducati Motorcycle Chat 16 Oct 18th, 2006 10:12 am
Track Day Bike Prep Experiences galaxy Ducati Motorcycle Chat 11 Sep 27th, 2006 2:11 pm
