Originally Posted by 2FLYRN
Hello all
Does anyone have experience with how uch an engine rebuild could cost. I have contacted several dealers and I canot get a straight anwer from any of them.
Engine is currently on the bike, and that is the way they want it. I am just trying to establish an estimate, I cant even get them to give me a worse case scenario!
Any help would be appreciated.
If you are just going to to do work on the top end, ie heads/cylinders/pistons/rings it shouldn't be bad, labor-wise [I can't quote you a number, as I do it all myself] Unless you are building it to go racing, then the head work can get a little expensive.
Internal work, mains bearings, con rods, tranny work [including output sahft bearing] etc. requires splitting the cases and is far more involved.
Why does it need to be rebuilt? Is it seized? Bearing knock? Blowing smoke?
In any case, I would think they would prefer it already out of the frame...unless they just want to make the extra money to pull it themselves.
