Nuts! Removed the clutch slave, replaced it and now no clutch action. - Ducati.ms - The Ultimate Ducati Forum
Graves MotorsportsMotorcycle.com Classifieds!
Patriot Powersports
Old Nov 22nd, 2006, 2:20 pm   #1 (permalink)
peteremsley's Avatar
I was replacing my chain and sprockets this am and I needed to remove the clutch slave to allow enough room for the front sprocket to come off.
I put everything back together and now no clutch... I never touched the banjo bolt, so I guess it must be mechanical. The rod did come out a little when I pulled the slave off. Any chance I might have dislodged something on the clutch side?
Your thoughts are appreciated!
Thanks.
a yellow one, an orange one, a blue one. i sold the red one.
peteremsley is offline   Reply With Quote
Old Nov 22nd, 2006, 2:38 pm   #2 (permalink)
try bleeding it.
www.ducati-owners-group.com
95 900SP
superduc21 is offline   Reply With Quote
Old Nov 22nd, 2006, 4:20 pm   #3 (permalink)
Iwannaduc's Avatar
You might have to pump it back up. Notice when you remove a rear wheel, you end up having to pump up the rear brakes before you use them. Otherwise the rear brake lever will go all the way down and you get no brakes..........sean
Who's April Miller, your girl friend?
Iwannaduc is offline   Reply With Quote
