Feb 3rd, 2012, 3:15 pm
aluminum clutch cover?
anyone know if my 96cr clutch cover is aluminum? I want to do some sanding on it and polish it up a bit.
rumor has it they are steel. But the paso cover is aluminum?
Feb 3rd, 2012, 4:19 pm
It's aluminum. See here for the polished and cut down cover on mine.
Making a trick clutch cover for your Ducati for free - Talking Bikes
JUST ANOTHER MOTORCYCLE PAGE==> TalkingBikes.org
82 Twinstar 200
84 V45 Magna
81 CB1000
84 V65 Sabre
89 PC800
09 Concours14
95 900ss
Feb 3rd, 2012, 4:28 pm
Use a magnet
me:
'76 Claus Bang
my girls:
'93 Ducati 900 Supersport
'76 Honda CB750 K6
Feb 3rd, 2012, 7:13 pm
When I bought my 1996 SS/CR it had a CF cover on it. I ended up buying a used PSR pressure plate for $50 and abandon the cover. I say let the clutch show!
Feb 4th, 2012, 1:58 am
Its alloy.
Altered my '95 SS cover using some bi-metal holesaws?
Have since polished it up using coarse -to - fine wet&dry paper, once you have vented the cover you will need stainless clutch springs & bolts, also a posh pressure plate!  Paint the standard one or get shopping...
Was'nt too keen on exposing too much rotating clutch in case I have an off and it ends up eating my leg...
Feb 5th, 2012, 3:14 pm
i have 2 that are modded and they are both steel.....
the steel ones have the flat mounting holes being pressed steel and as you can see in those pictures the alloy ones have a raised mounting hole, being cast hope that helps??
they made both, the later models i believed used the steel over alloy.
1995 900ss, 2002 injected 900ss turbo, triumph 675 front fairing off a race bike modded for street, 916 rear tail section and a few other mods.
Feb 5th, 2012, 4:11 pm
think he is more after the look and not planning on low siding it like the rest of us haha we are discussing street bikes here not race bikes, last thing we want to do is low side our bikes let alone high side it for that matter lol
alloy and carbon are better for bling value but as RIC did mention if you want protection over anything else with a little bling value then yes as RIC mentioned, billet is the way to go
Feb 5th, 2012, 5:40 pm
thanks for the help guys, hit it with some sandpaper last night. looking ok so far
Feb 5th, 2012, 11:47 pm
that is a pressed steel cover just like my one and mine, see the holes where the bolts go threw, see how thin the meterial is and these are also made from 2 parts, if you are going to drill a hole threw it you will see where the 2 parts have been pressed together., also if you look at the alloy ones, you will see they are raised about 10mm, you can still polish it just clear coat it after  i have painted mine black.
