External Fuel Valve install - Ducati.ms - The Ultimate Ducati Forum
Graves MotorsportsMotorcycle.com Classifieds!SportbikeTrackGear
Old Feb 2nd, 2012, 6:03 pm   #1 (permalink)
1996900sp's Avatar
Since I bought it new my '96 900SP has leaked fuel past the Float Valves no matter what I tried, including new float kits and a new undertank petcock so the solution was to mount an external fuel valve. I used a Pingel Part # 6250-AH 3/8 NPT Hex. I made a bracket and mounted it to the inner fairing bolt position. It works perfect and no more leaks and tucks into the space quite nicely.
1996900sp is offline   Reply With Quote
Old Feb 2nd, 2012, 8:02 pm   #2 (permalink)
shut off
Nice job , thanks for the info.
450RT is offline   Reply With Quote
Old Feb 3rd, 2012, 2:33 am   #3 (permalink)
strong vacuum sound, hold wallet tightly
holy crap. $86 for a fuel shutoff valve? I've got a crap little motion pro that I put in last year when the tank shutoff stopped working. Put the filter external also. This pingel one is 100 times nicer looking than mine and cool that it's hard mounted to the frame.
thanks for putting the pictures up. This is the nicest execution of the external fuel valve I've seen so far.
bananaboat is offline   Reply With Quote
Old Apr 11th, 2012, 9:44 pm   #4 (permalink)
Jeff_H's Avatar
2nd Spring in a row that I've had to "unstick" my float bowl needles...I'm doing this. Thank you for posting!
Regards,
Jeff
"Keep your blood clean, your body lean and your mind sharp." ~ Rollins
'98 944 CR
Jeff_H is offline   Reply With Quote
Old Apr 12th, 2012, 7:58 am   #5 (permalink)
LeoLegend's Avatar
you guys must let your bikes sit for a while I'm assuming? It's never happened to me in 6 or so years. *knock on wood*
LeoLegend is offline   Reply With Quote
Old Apr 12th, 2012, 11:18 am   #6 (permalink)
Jeff_H's Avatar
The riding season is only 6-7 months long where I live, so she has to sit for a while each winter.
Jeff
'98 944 CR
Old May 10th, 2012, 10:26 pm   #7 (permalink)
CaribooBC's Avatar
I just had my 94 900ss fill my horizontal cylinder with fuel, it has 41 FCR's on it. Is there an easy fix to the float needle sticking on these carbs? Also when it has done it once, will it keep sticking?
'94 900 SS CR, '95 900 SS CR, '86 Honda NS400R, '82 Gpz 550.
CaribooBC is offline   Reply With Quote
Old May 11th, 2012, 8:05 am   #8 (permalink)
punch455's Avatar
Tapping gently on the side of the bowl may free it up temporarily. But in all reality, pulling the float bowl and inspecting the needle is pretty easy. While the bowl is off, you can spray some compressed air into the needle seat to clear out anything that may be stuck in there which is hanging the needle up and keeping it from seating. Once you do that, and inspect the needle, reassemble it and make sure the needle is sliding smoothly and seating properly by hand. If so, button it all together again!
1997 900SS/SP C15
1978 CB750F SS
punch455 is offline   Reply With Quote
Old May 11th, 2012, 5:30 pm   #9 (permalink)
Some carbs have floats which have a tang that you bend to limit float drop. You bend the tab to limit how much needles drop in seat before hitting the stop. Make sure if you have these float travel limiters that they are adjusted so no more than half of the needle can come out of the seat before the float hits the stop tab. Some times they forget to mention this adjustment, which can allow the needle to drop too far and
duc96cr is offline   Reply With Quote
Old May 11th, 2012, 5:31 pm   #10 (permalink)
Stick.
external fuel filter mod RockingM Sport Touring 8 Jun 29th, 2011 10:11 am
Fuel Shutoff Valve (Avoid fuel in sump) dsmess Supersport 3 Feb 20th, 2011 9:12 am
External fuel filter - 900SSie etc. Punch Supersport 4 Mar 20th, 2008 6:39 pm
