Choices for EFI replacement - Ducati.ms - The Ultimate Ducati Forum
SportbikeTrackGearMotorcycle.com
Old Jan 26th, 2012, 2:20 pm   #1 (permalink)
Catimann's Avatar
I read the Power Comander post, where you trade maps and have to ask if there are other choices. I have a 93 Bimota DB2 with the 900ss motor which Bimota fitted EFI to.
The computer for this is a dinosaur and could not be repaired if it died. I see most use the PC but is there more choice?
Thanks
Andreas
93 DB2, 74 MG 850 Eldorado police, 93 KLR 250, 06 DRZ400SM
Catimann is offline   Reply With Quote
Old Jan 26th, 2012, 5:27 pm   #2 (permalink)
BakonDuc's Avatar
I may be wrong, but if the ECU on your DB2 is anything like one on the injected SS, the Power Commander (and Dobek Teklusion, etc.) doesn't replace the ECU, it works in conjunction with the ECU to modify the injector "squirt" timing signal that the ECU is sending to each injector.
Hopefully others will have some kind of remedy for you.
Bryan
1999 900 Supersport
1984 Moto Guzzi V65 SP
2004 KTM 625 SMC
BakonDuc is offline   Reply With Quote
Choices ForzaDuc Superbikes 0 Mar 7th, 2010 9:08 pm
choices choices mike996 Superbikes 3 Apr 30th, 2007 10:15 am
2 choices bpad1 Ducati Motorcycle Chat 4 Jan 18th, 2007 4:02 am
Choices ? Keyboard Ducati Motorcycle Chat 11 Aug 20th, 2006 7:01 pm
Choices Keyboard Superbikes 13 Aug 15th, 2006 9:33 pm
