SS front end conversion to 53mm SBK - Ducati.ms - The Ultimate Ducati Forum
Old Jan 22nd, 2012, 12:36 am   #1 (permalink)
DesmoDerek944's Avatar
Has anyone done this conversion lately? I am beginning my project this spring and have a few questions? Will be using a brand new replacement frame (one was cracked) and need to source new steering head bearings. Anyone know what the bearing(s) mfg #'s are? (not the Ducati part #)
desmoderek@msn.com
Derek E. Davenport
479-790-9080 cell/text
1996 Ducati 900SS/SL Replica (project)
1997 Ducati M900 Monster
2000 Triumph 955i Daytona
1995 Ducati 900SS/SP (sold)
1994 BMW R1100RSL (sold)
1985 BMW K100RS (sold)
DesmoDerek944 is offline   Reply With Quote
Old Jan 22nd, 2012, 3:10 am   #2 (permalink)
Steering bearings
The spare pair I have here are both marked 639174 (inner and outer) and they measure 26X52X15. I had another pair I bought a while ago but any half decent bearing supplier should have them on the shelf.
If you search "bearing 639174" you will get quite a few results. SKF 639174 26X52X15
Tapered roller bearing SKF 639174 26 x 52 x 15.30 mm-Grene Webshop
Can't help with the other question - I replaced my fork internals (AK-20 kit)for probably the same money but seemed to be the easy option.
1993 Ducati 900SS
1984 Honda VF1000RE
He was as lame as a duck. Not the metaphorical lame duck either, but a real duck that was actually lame. Maybe from stepping on a pebble and rolling an ankle.
TassieDave is offline   Reply With Quote
Old Jan 22nd, 2012, 3:45 am   #3 (permalink)
Pablo Pirate's Avatar
Images: 9
Howdo!!
Used a set of 1098 forks on my Superlight - however the top yoke doesn't have enough meat on it so I had a set of adjustable yokes made by Pro-Mach. Very good upgrade, especially with the radial brakes.
Cheers Pablo
Pablo Pirate is offline   Reply With Quote
Old Jan 22nd, 2012, 10:31 am   #4 (permalink)
amehl's Avatar
I JUST did this. Finished it about 2 weeks ago. Also if you are using **8/**9 forks you dont need different steering bearings. I got mine from All Balls, they seem ok.
I started my SBK fork upgrade...
1999 750SS
amehl is offline   Reply With Quote
Old Jan 22nd, 2012, 3:27 pm   #5 (permalink)
countcoupe's Avatar
Yep, done it myself!
916 Front Fork Conversion Completed
Had the top yoke milled out to fit and shimmed out the forks for the bottom yoke.
Got a 916 front wheel and spindle and mudguard to go with the 916 forks!
Played around with the internals of the speedo drive!
Lowered the clocks in the front subframe so I could use 916 clipons.
Hey presto.
Charlie
countcoupe is offline   Reply With Quote
Old Jan 22nd, 2012, 3:30 pm   #6 (permalink)
countcoupe's Avatar
More recent picture.
Old Jan 22nd, 2012, 3:58 pm   #7 (permalink)
Hi, did this on my old 900SS and just done it again on my 851 (same front end as the SS/SL)
Get your top yoke machined out to 53mm, shim the bottom down with 1/2mm plate.
Wheel, axle and nut, mudguard, speedo drive, calipers and discs, bars from a 748, 916, 996, 998, SSie, any ST, any Monster of the S2/S4 era.
Get early 916 forks with 40mm caliper mounts and you can use your SS calipers.
The new front wheel won't match your existing rear as the spoke pattern is different. The only direct fit wheel that matches is from the 900SSie, these are very rare. The 600 and 750 were only 4.5".
You could probably fit a Monster ie or ST rear wheel but these run a 25mm axle so you'd have to modify your swingarm and adjusters or (probably easier) make a spacer to run a 17mm axle in the 25mm bearings.
Good luck!
"If you need me to explain why I want to do it, then you will never understand."
1991 851 Strada
- ST4 Engine
- 996 Showa Forks
- Ohlins Shock
- Alloy SP Subframe
- 50mm Exhaust
- Carbon everything
- No lights or mirrors because they're for girls
dhumphrys is offline   Reply With Quote
FS: 53mm clip ons jpen Parts and Accessories 1 May 15th, 2011 11:27 pm
916 Front Fork Conversion Completed countcoupe Supersport 11 Nov 21st, 2010 3:58 am
Free floating front brake rotor conversion jpen Superbikes 9 Oct 28th, 2007 7:43 pm
clip-ons 53mm / 53.5mm bungi Superbikes 0 Feb 27th, 2007 2:35 pm
