Negative Battery Cable - Ducati.ms - The Ultimate Ducati Forum
Old Jan 17th, 2012, 10:15 am   #1 (permalink)
punch455's Avatar
Just a quick regarding the battery -
I removed the battery cables about a month ago just to do some tidying up under the tank, and for the life of me, I can't figure out where the negative cable attaches to the frame! The only boss on the frame that I see is where the CR fairing bracket goes on the half fairing models. (mine is a 97 900SP). I checked the parts fiche but it doesn't show the actual grounding point.
Anyone know off hand where it bolts to?
Thanks in advance everybody!
-Max
1997 900SS/SP C15
1978 CB750F SS
punch455 is offline   Reply With Quote
Old Jan 17th, 2012, 10:36 am   #2 (permalink)
sirduke's Avatar
That's where it's attached on mine
'93 900SS.
'09 Suzuki GSF1250K9 Bandit
'89 Suzuki GN250 (project)
UK Bikers
sirduke is offline   Reply With Quote
Old Jan 17th, 2012, 10:41 am   #3 (permalink)
Ditto on my '94. Just in front of the battery, on the inside of the frame. There should be another negative lead there that runs up to the wiring harness in the front.
1994 900SS My first Duc
Other ride: 1978 Yamaha XS 750 E
The perpetual Cafe Racer project
Drdds is offline   Reply With Quote
Old Jan 17th, 2012, 11:17 am   #4 (permalink)
punch455's Avatar
Ah great. Thanks a bunch for the help. I don't see that negative pigtail for the front wiring harness on mine - but everything is working.
Thanks again!
1997 900SS/SP C15
1978 CB750F SS
Old Jan 17th, 2012, 11:25 am   #5 (permalink)
On my '97 and '98 the wire connects to the frame at the left, rear airbox mounting point.
1997 900 SS/SP track bike
1998 900 SS/FE #299
Joe-B is offline   Reply With Quote
Old Jan 17th, 2012, 11:26 am   #6 (permalink)
Run another big-core ground lead straight from your battery to the engine ground point, by the righthand footrest - for MUCH better cranking!
Old Jan 17th, 2012, 11:43 am   #7 (permalink)
sirduke's Avatar
Add a Powerlet rewire kit for the positive side too, and you can virtually ride it on just the power from the starter
'93 900SS.
UK Bikers
Old Jan 17th, 2012, 11:52 am   #8 (permalink)
punch455's Avatar
At the risk of opening a can of worms here ( I know everyone has preferences for their own wiring to improve cranking on these bikes).. can I ask specifically how you have the negative system wired? Mine is - I think - stock, as I have a cable from the battery anode to the frame, then a small negative jumper from the frame to the engine block at that point you mentioned above, near the right footpeg.
Are you saying that you run a thick gauge wire directly from the battery anode to the engine block?
1997 900SS/SP C15
1978 CB750F SS
Old Jan 17th, 2012, 12:23 pm   #9 (permalink)
sirduke's Avatar
Yes.
Go to a car parts stockist and buy a 60cm battery earth lead with flat terminals and bolt it in place. I left the originals in place too.
'93 900SS.
UK Bikers
Old Jan 17th, 2012, 1:21 pm   #10 (permalink)
Originally Posted by sirduke View Post
Yes.
What he said.
Make sure all connectors are clean,degreased etc before fitting - have just added a fat lead straight from the battery positive terminal to the solenoid, also leaving the originals in place? The standard positive lead goes into a splitter block, one lead goes to the solenoid - the spade type connector in this connector cannot be anything but a point of high electrical resistance... now spins over like an IL4.
DIY: 696/796/1100 battery cable and battery upgrade romancommander Monster 16 Jan 2nd, 2012 11:37 pm
999 Negative cable grounding out... ZDM Superbikes 8 Nov 18th, 2011 5:14 pm
DIY Battery Cable in HD ! ww321q Superbikes 2 Apr 7th, 2011 6:20 pm
848 battery cable and 30 amp fuse? horwitzs Superbikes 6 Jan 17th, 2011 3:45 pm
Negative Battery Cables Cut jhodge81 Superbikes 0 Aug 19th, 2009 10:33 pm
