Noob question 1994 900ss front brakes - Ducati.ms - The Ultimate Ducati Forum
Old Jan 15th, 2012, 7:15 pm   #1 (permalink)
I have picked up a 94 900ss and am going to bring it back to life. My first trouble was when pulling the front brakes, the calipers would not clear the inside of the rim when pulling them back off the disk. I just ended up pulling the disks as the wheels are going out for paint, but what am I doing wrong, the bike has brembo calipers, 17" brembo front rim. I have never had an issue like this before, thanks for your help.
T
tr0y is offline   Reply With Quote
Old Jan 16th, 2012, 1:52 am   #2 (permalink)
I almost did the same thing myself the first time I took off the calipers, but the trick is just to gently roll them off the of disc, or to gently pull and push the capiler to compress the pads a little first, before rolling them off. This should allow the caliper to pivot around the disc without hitting the rim.
1993 900SS
Berkeley, CA
David_V is offline   Reply With Quote
Old Jan 16th, 2012, 3:20 am   #3 (permalink)
Iconic944ss's Avatar
The 320mm discs do make the gap very slim for getting the calipers off.
As has been suggested try gently rolling the caliper away from the centre line of the bike over the disc (try putting a cloth between the caliper and the inside of the wheel rim to protect the metals)
or / and
try removing the pads from the caliper as well, the extra clearance from not having the pads in place makes the job easier.
Good luck.
Currrent Bikes:
1993 944SS: Everything has been fiddled with
2001 ST4S: The new kid on the block
2001 Aprilia Falco: Ohlins forks, Oz wheels = Stealth Fighter.
My 900ss Resource: http://900ss.proboards.com/
Iconic944ss is offline   Reply With Quote
Old Jan 16th, 2012, 8:30 am   #4 (permalink)
Baffled's Avatar
As you remove the calipers pull them back as close to the rim as you can then pull them slightly sideways, just enough to increase the pad gap & they will come right off....
Baffled is offline   Reply With Quote
Old Jan 16th, 2012, 10:45 am   #5 (permalink)
Pull the pads out first-its not hard or time consuming
gusman77 is offline   Reply With Quote
Old Jan 16th, 2012, 11:19 am   #6 (permalink)
No need, just press pads apart slightly and the caliper will come off easily.
1997 900 SS/SP track bike
1998 900 SS/FE #299
Joe-B is offline   Reply With Quote
Old Jan 17th, 2012, 5:35 pm   #7 (permalink)
Thanks guys, now I know for next time. The bike is in teardown mode so this time it didn't matter. I just felt dumb...
Hi All - New 1994 900ss Owner Here tr0y Welcome and Introduction 0 Jan 14th, 2012 7:00 pm
1994 900SS/CR Forks Kpenttila Supersport 7 May 24th, 2011 9:18 am
Bleeding front brakes 999-question.... ZDM Superbikes 7 Jul 9th, 2010 8:10 am
Scored! 1994 900SS SP joepopp Supersport 3 May 19th, 2009 11:54 am
Is my 900ss really a 1994 modell? Pepita Supersport 5 Apr 6th, 2007 1:31 am
