Jan 15th, 2012, 5:45 am
Stuck chain adjusters
HI
On the RHS aluminium swing arm of my 900SS, I cannot turn the adjuster bolt in any direction. Tried CRC spray, oil, etc but no go
I am certain I would ruin the bolt if I use too much force.. Any suggestion please
rgds
William
Jan 15th, 2012, 6:19 am
If you have the means to support the rear of the bike and remove the rear wheel, do it. Then take both adjuster out of the swing arm, clean the adjusters up and grease the threads on the adjuster bolts. While you there clean the axle and everything else you don't normally have access to.
Jan 15th, 2012, 7:43 am
Penetrating oil, heat, patience. Repeat. They are a bugger when frozen.
1997 900 SS/SP track bike
1998 900 SS/FE #299
Jan 15th, 2012, 8:34 am
most definately do that.
I'd highly recommend when you reassemble you use anti-sieze compound on the threads, help keep it from happening again.
Chris
12 1199 Panigale......May 26th?????????????????????
10 Ducati Streetfighter
2011 Aprilia RSV4-R APRC
05 Goldwing
Jan 16th, 2012, 3:28 am
Thanks guys will try it, hope the bolt does not break in the thread
Cheers
W
Jan 16th, 2012, 8:06 am
Cheers
W
I had exactly this situation on both sides of my 95sssp when I first got the bike. The key for me was never turning the bolts anywhere near hard enough to risk damaging them, no matter how frustrating it was. penetrating oil, heat, back and forth with the wrench, little tap with the hammer, penetrating oil, heat, wrench.... Each side took about 20-30 minutes if I remember right. Rusty mess inside once they came out.
Jan 20th, 2012, 2:33 am
Thank you guys; now trying to explain to the locals what "penetrating oil" is has got me almost insane...
May have to get some from either Oz or US grrrrr
Cheers
W
Jan 21st, 2012, 12:04 am
Do you have easy access to a bit of diesel. That can be just as good sometimes.
1993 Ducati 900SS
1984 Honda VF1000RE
He was as lame as a duck. Not the metaphorical lame duck either, but a real duck that was actually lame. Maybe from stepping on a pebble and rolling an ankle.
Jan 21st, 2012, 1:51 am
I read about making homeade penetrating oil using diesel and I think automatic trasmission mixed 50/50 or something like that.
Jan 21st, 2012, 2:06 am
Depending in the state of the threads you could drill out the old threads and fit a helicoil/thread insert either side?
