Yep, thank you. That answers it... Not valid for my 2006 800ss
"On the left an older 1991-2000 style slave cylinder. This generation also came with the banjo attaching at the top instead of the front of the slave. The Evo piston upgrade is designed for Type 1 Slave cylinders. On the right, the Type 2 new style slave used since 2000. If you have this style of slave cylinder, this product WILL NOT fit. There is no replacement piston for the Type 2 newer style slaves."
2006 800ss
