Lower fairing brittle plastic question
I took the fairings off on the weekend and gave them a good clean inside & out, also ripped out the disintigrating firewall/material ifrom the middle portion of the fairings (not too concerned about that, should I be?). What does concern me is that of the 4 closures with bolts for the bottom seam of the fairing, the plastic O shaped ring for the front bolt of each set of 2 was brittle and basically fell off when I unscrewed the fairing. Considering the back of it sits about 2cm from the rear tyre and its now only fastened with 2 bolts, 1 front, 1 rear I'm a little worried it might break & rub on the tyre or something & have been considering replacing them. Then I looked up prices and saw each half would be about $500 (so $1000) from commoto by part # so have been thinking of sharkskins & getting the street top & bottom. I'm wondering if any of you other new shape SS owners have had problems like this & how you solved them?
Also, quick noob question of the day: cleaned & lubed my chain... then went out for a ride today, found chain lube on the side of the tyre where the chain is. Have given it a wash & scrub on the tyre to try get it out, but it seems there is still some residue there. Should I be overly concerned about this? What should I do about it?
2003 Ducati Supersport 1000DS
1983 Honda GB250
1981 Suzuki GN250
