Air Box Cutting - Ducati.ms - The Ultimate Ducati Forum
SportbikeTrackGearGraves MotorsportsMotorcycle.com Classifieds!
Old Jan 8th, 2012, 6:46 am   #1 (permalink)
Daniel Wickers's Avatar
Air Box Cutting
Been reading about cutting the top off my air filter box (currently fitted with K+N Filter)
What are the results/benefits if any? don't really want to start messing about with it if there is no real gain?
Cheers guys :-)
Daniel Wickers is offline   Reply With Quote
Old Jan 8th, 2012, 10:20 am   #2 (permalink)
Sofa King's Avatar
If you have stock jetting then I think this will do little more then make your bike run lean. the stock main jets on the Mikunis are 140's, and that's fine for the stock airbox and pipes. Just adding the K&N isn't enough to warrant a rejet, but opening up the stock airbox would be. if you have stock pipes I'd go with a 144, and if pipes are modified too I'd consider 150's. I have 150 jets on mine with K&N, open airbox and free flow cans. in fact its so much richer that until I cut open the airbox it would not run right. It was too rich. I actually prefer the engine to run a bit too rich to keep the EGT down and protect the valves/pistons/head.
JUST ANOTHER MOTORCYCLE PAGE==>TalkingBikes.org
82 Twinstar 200
84 V45 Magna
81 CB1000
84 V65 Sabre
89 PC800
09 Concours14
95 900ss
Sofa King is offline   Reply With Quote
Old Jan 8th, 2012, 10:37 am   #3 (permalink)
OOTV's Avatar
Definitely look into the jetting. The one one non-performance benefit is the sound. It does change it to lgown one growl, particularly when backing off the throttle. When I had my very first service done, I had the K&N, air box cut and a stage two jet kit installed (at least I think it was a stage two, this was back in 95 so mem is a little fuzzy) and the one thing that I noticed right away was the sound had changed. Of course once I started riding it I could feel a slight difference in power. I have since changed the rear sprocket 2 teeth lager and the of line performance is much better!
OOTV is offline   Reply With Quote
Old Jan 8th, 2012, 11:52 am   #4 (permalink)
Ritlee's Avatar
What if the bike is ie? would the computer compensate?
'99 750SS
'07 Sportster 1200(sold)
'81 Honda CB750C (sold)
US Army Reserves, 14 years and counting
Ritlee is offline   Reply With Quote
Old Jan 8th, 2012, 1:46 pm   #5 (permalink)
catilover's Avatar
Images: 5
i run pod filters on 6" runners on my 2002ie motor with open pipes in my 95 frame and it doesn't run lean at all, runs a little rich if anything (little puffs of black smoke when WOT from low rpm's) and i run a A/R gauge.
1995 900ss, 2002 injected 900ss turbo, triumph 675 front fairing off a race bike modded for street, 916 rear tail section and a few other mods.
catilover is online now   Reply With Quote
Old Jan 8th, 2012, 3:17 pm   #6 (permalink)
ProfessorX's Avatar
When I had my 800SS tuned for the track, the tuner (J.D. Hord--hordpower.com) found only a 1 hp difference between stock and open airbox.
Ducati 800SS
Moto Series Novice #5
(motoseries.com)
Cogent Dynamics(motocd.com)
"Live truth instead of professing it."--Elbert Hubbard
ProfessorX is offline   Reply With Quote
Old Jan 8th, 2012, 3:32 pm   #7 (permalink)
lior_baruch's Avatar
I got a 1993 750SS, just got my K&N and cut mine.... glad to see your answer (and the thread's question, of course )
Anyone knows where to buy a 144 jets for the Mikuni BDST38?
Thanks,
Lior.
lior_baruch is offline   Reply With Quote
Old Jan 8th, 2012, 5:18 pm   #8 (permalink)
stoshmonster's Avatar
Maybe PJ Motorsports might have what you're looking for. Click me.>>>>>Buy Mikuni Jets @ PJMotorsports.com
'95 900SS CR affectionately known as "The Pizza Wagon"
stoshmonster is offline   Reply With Quote
Need help please - 748 cutting out ajt Superbikes 23 Jan 7th, 2012 1:09 pm
cutting out SpydieNut Monster 3 Aug 26th, 2010 5:40 am
Help me!! 748 is cutting out at low rpm.. Hoffy748 Superbikes 3 Sep 1st, 2009 8:55 pm
ST2 Cutting Out AggieRider Sport Touring 7 Feb 1st, 2009 11:33 pm
888 cutting out idb Superbikes 21 Nov 14th, 2006 5:34 pm
