Was thinking at work today... - Ducati.ms - The Ultimate Ducati Forum
Old Jan 6th, 2012, 11:35 am   #1 (permalink)
- would a measure of two-stroke oil in my tank stop my tank from rusting/rusting further? Longterm, yes - I will be POR-15 sealing the thing, just thinking short-term. Would make the bike smell nice as well as sound nice
- do 848 clutch plates fit a dry-clutch basket? Being wet-clutch plates you could then convert the cover so the clutch ran part-immersed in an oil-bath, stopping any dry-clutch premature tab & plate wear (& noise...)
Old Jan 6th, 2012, 4:00 pm   #2 (permalink)
Hi,
The only problem I see with running 2 stroke oil in the gas tank is, the fuel and oil are lighter than the water. So the water will still seperate out and settle on the bottom of the tank. I don't think it will hurt to try it, I'm just not sure it will work as well as you hope.
Sorry but I can't help with your clutch question.
Cheers,
Bill
1968 Gilera SS
1969 Honda Trail 90
1986 Honda 750 VFR Intercepter
1994 Ducati 900 SS CR
2001 aprilia RST Futura
Bill T is offline   Reply With Quote
Old Jan 6th, 2012, 4:00 pm   #3 (permalink)
I'm just guessing, but I would think if you got enough in there to actually have any value for the rusting issue that you'd be fouling plugs. Not sure how the fuel injection would do with that either?? Interesting question.
1999 900SS Red
REVNH is offline   Reply With Quote
Old Jan 6th, 2012, 4:17 pm   #4 (permalink)
I don't think adding oil is going to make any difference to the rate at which the tank rots. Your bike would be off the road for a couple of days but it would be worth sealing it.
As I say to my kids, "When's the best time to do anything?" The answer is, "Right now".
Flash Harry is offline   Reply With Quote
Old Jan 6th, 2012, 6:42 pm   #5 (permalink)
944SS's Avatar
I'd think any sufficent concentration of 2 Stroke oil that would coat the tank to help prevent rust would affect your performance. I'd stick to adding Stabil or simple methyl hydrate to your tank to absorb the water every six months when not in regular use.
'98 900 SS FE (#028)
'93 900 SS Superlight (#679)
'78 900 SS.......'74 750 Sport
944SS is offline   Reply With Quote
Old Jan 6th, 2012, 7:15 pm   #6 (permalink)
Methyl Hydrate?? - will ordinary meths ( methylated spirits ) do the same job near enough?
1992 900 SS
2004 CBR1000RR
2004 CBR1000RR track
JAFA is online now   Reply With Quote
Old Jan 7th, 2012, 4:13 am   #7 (permalink)
+1
- so the Methyl absorbs the water, then is absorbed into the petrol?
Bike is a '95 carby, so no probs with the injection system etc...
Ideally I need to try an 848 plate in the spare basket to see if it will fit? Cant see any being that knackered yet tho.
Old Jan 7th, 2012, 10:47 pm   #8 (permalink)
Isopropyl Alcohol also "absorbs" any water in the tank and converts it to a combustable substance, should be available from any hardware store or car painter, 1/2 a litre is plenty.
NZDAVE, Invercargill, New Zealand, 2003 800SSie
nzdave is offline   Reply With Quote
Old Jan 8th, 2012, 1:32 am   #9 (permalink)
paulmm600's Avatar
i put a little metho in every six months whether the bike is sitting or not just incase there's any water in the fuel.
cheers
paul
916 biposto 96' current
M600 00'
Mille S2 84'
paulmm600 is online now   Reply With Quote
Old Jan 8th, 2012, 3:22 am   #10 (permalink)
Cheers guys! The tank itself is empty, just stripped it to remove/relocate the fuel filter so needless to say its dry of all water & fuel at the mo... We are currently having a very mild Winter here in the UK so I may be refitting it later today and going off out for a ride...
nzdave - what dose are we looking at for say half-a-tank of fuel?
Rode into work today il_randy Sport Touring 13 Mar 1st, 2011 10:23 pm
Did some service work today Blue2001ST4 Sport Touring 4 Feb 15th, 2011 1:00 pm
Rode to work today. FatherWarrior StreetFighter 7 Oct 20th, 2010 5:46 pm
Rode to work today... Da_Bull Superbikes 2 Mar 13th, 2009 1:38 pm
First Commute to work today Hammerman Sport Classic 15 May 20th, 2008 7:05 pm
