Jan 2nd, 2012, 2:03 pm
Quick spark plug question
According to the manual my 1992 Superlight needs Champion RA6HC spark plugs.
However, NGK plug are easier to get by.
Most online shops offer NGK DPR8EA-9 or NGK DCPR8E plugs for the SL.
Are these any good as a stock replacement?
What's the difference between the two?
Ducati 900SL MK I n° 92 | Ducati 900SS '94 Trackbike
Jan 2nd, 2012, 2:17 pm
For my monster I interchange DCPR8E and DCPR8EIX with the Champion RA6HC. They are essentially the same except the EIX didn't come with the little screw on caps and I had to dig some up.
Mike
Jan 2nd, 2012, 2:25 pm
The shop I work out sells NGK exclusively. It seems like Champions foul out pretty quick comparatively. Plus Harley's and lawn mowers use Champion so we just lump them in the crap catagory.
DPR8EA-9 12mm thread, Protruded electrode, Resistor type, 19mm length thread, special firing construction, and wide gap to .9mm
DCPR8E 12mm thread, protruded electrode, resistor type, 5/8 hex drive, 19mm length thread
So basically the difference is the electrode design, gap, and drive style.
NGK references the DCPR8E for your app
Jan 2nd, 2012, 2:26 pm
in your case the IX just denotes the plug as Iridium instead of standard. And yeah, good thing to save your screw on terminals. Most NGKs don't come with them.
Jan 3rd, 2012, 6:16 am
NGK plugs have served me well, but for some reason (probably to be different and/or snobby) I'm running Denso plugs. They look sharp!
Here is all the info you'll need to know to choose a plug, NGK, Denso or Champion:
Heat range conversions :
Ducati 900SS '99
Honda MC21 NSR250SE
KTM 200EXC 2010
Jan 3rd, 2012, 8:16 am
Ngk d8ea
You don't need resistor plugs in that bike. You will need a new socket though. I forget what size; 18 mm?
1997 900 SS/SP track bike
1998 900 SS/FE #299
Jan 3rd, 2012, 10:11 am
I think I have 3 different spark plug sockets in the toolbox, must be one that fits
The Ngk d8ea would shave off some euro's
Strange that everywhere resistor plugs are offered. Even the stock ones are resistor plugs.
Jan 3rd, 2012, 5:09 pm
Here is a good plug cross reference: Spark plug cross reference
The Denso X24EPR-ZU9 platinum electrode plugs looks good.
Ducati 900SS '99
Honda MC21 NSR250SE
KTM 200EXC 2010
Jan 3rd, 2012, 6:04 pm
That 18mm socket caught me out. I had to go out and buy one. Very annoying when you're almost finishing a job.
With non resistor plugs everyone you go near with an electronic item attached to their vehicle will know you're there. The range is limited and effects vary but the old style plugs can interfere with electronics of many kinds. Radio is the most obvious but maybe GPS or other onboard electrickery?
