Slightly longer sidestand for a '98 900SS? - Ducati.ms - The Ultimate Ducati Forum
Old Jan 1st, 2012, 8:31 am   #1 (permalink)
I've installed a stock shock from a '99 900SS on my '98. The shock is a bit longer than the original, so the bike leans over a bit much. Is there a sidestand from another model that will bolt on which is a bit (1/2" or so) longer? Right now I'm too lazy to cut and weld the original one.
thanks,
-Armen
'98 900SS/FE
Spirito d'argento
Armen is offline   Reply With Quote
Old Jan 1st, 2012, 9:30 am   #2 (permalink)
Images: 14
sidestand
Hey Armen
I also added a longer Ohlims shock to my bike last year and need aboooooout 1" longer on the sidestand..
I have surfed quite a bit but found nothing!!
If I do find something I will send you a PM!
Mike S
Mike S
1996 900SSCR
Tastefully modded.
Then Modded AGAIN!!!
2005 ST3.....sold
2003 ST4S W/ABS YES!!!
Secretary DucsUnlimited..find us on FaceBook!!
Ducoddy-SS is offline   Reply With Quote
Old Jan 1st, 2012, 12:47 pm   #3 (permalink)
I'm going to look into an ST sidestand . I've got a friend with an ST2 and I want to see if his will fit my 96 SS. I'm pretty sure it will bolt on easily enough , but don't know if the stand part will clear the exhaust . Cycle cat makes longer stands for the ST mount so if it will work that would be an easy solution .
Ron
rond944 is offline   Reply With Quote
Old Jan 1st, 2012, 5:31 pm   #4 (permalink)
Moderator in Moderation
edwyun's Avatar
Images: 30
It does lean further but never had any issues with the normal sidestand.
Ride Safe,
Edward
'72 750GT
'98 900SS/FE
IBA #18798
http://webspace.webring.com/people/ue/edwyun/
(including the FE Registry)
edwyun is offline   Reply With Quote
Old Jan 2nd, 2012, 2:36 am   #5 (permalink)
Pablo Pirate's Avatar
Images: 9
Howdo!!
Fitted an extended body on my Ohlins shock to quicken the steering on my Superlight, welded the standard Alloy stand but caught it on a trip to Italy which broke at the weld and had to carry a brick round to stick under the half a stand (Not good for the power to weight ratio)
Fitted a ST3 stand and all's good bike sits perfect.
Cheers Pablo
Pablo Pirate is offline   Reply With Quote
Old Jan 2nd, 2012, 7:11 am   #6 (permalink)
Got a lengthened Fox shock on my carby - are the stands longer on the injection SS's due to the longer shock? has anybody got a carby & IE stand they can compare?
Old Jan 2nd, 2012, 4:50 pm   #7 (permalink)
Hey Pablo Pirate , thanks for the vindication of my idea of using a stand off of a n ST . One question . When the stand is retracted in the up position , does it sit closer inboard ? The stock stand on my 96 slightly fouls my boot with my DP rearsets . The ST stand looks like it would give me a little more clearance there in addition to being longer and holding the bike more upright at rest .
Thanks
Ron
My 999R slightly modded..... brust60 Superbikes 12 Apr 25th, 2009 5:27 pm
Possible option for longer/taller sidestand for 748/916/996/998? Dana Superbikes 11 Sep 9th, 2008 3:58 pm
Self-retracting sidestand on 900SS FE josephvman Supersport 7 Aug 6th, 2008 12:04 am
Idleing on sidestand vs. sidestand cutout dnldfte Superbikes 4 Apr 5th, 2007 12:26 pm
Value of a (slightly beat up) 1993 900SS RichinPeoria Supersport 11 Nov 17th, 2006 3:37 pm
