'93 900ss choke issue - Ducati.ms - The Ultimate Ducati Forum
Old Dec 31st, 2011, 3:45 pm   #1 (permalink)
My coke does not stay open when I start my bike. I can't see anything broken. Its a if a spring on the rod is missing because it just shoots back closed.
themagicm is offline   Reply With Quote
Old Jan 4th, 2012, 10:59 pm   #2 (permalink)
So did everyone convert to fuel injection or what? Sarcasm intended.
Old Jan 5th, 2012, 12:22 am   #3 (permalink)
I fitted FCR41s. So no choke for me.
Just checked the junk pile and the choke is spring loaded at the carbies. The lever assembly (that is mounted to the clutch master cylinder) has plastic bumps moulded into it that should hold it in position so they could be worn down.
But I broke a bit off that assembly when I removed it - bumps are still all there and did used to hold mine with the choke open.
1993 Ducati 900SS
1984 Honda VF1000RE
He was as lame as a duck. Not the metaphorical lame duck either, but a real duck that was actually lame. Maybe from stepping on a pebble and rolling an ankle.
TassieDave is offline   Reply With Quote
Old Jan 5th, 2012, 12:56 am   #4 (permalink)
x7821's Avatar
My choke does not stay open by itself ('93 900ss with stock carbs). I have come accustomed to just adjusting it by hand as I warm the bike up. Never bothered to research/fix it. I always just thought that was kinda how they worked.
x7821 is offline   Reply With Quote
Old Jan 5th, 2012, 6:49 am   #5 (permalink)
Mine used to hold in place, until I also went to FCR's.
Now it's three squirts for a cold morning and one on other days.
Flash Harry is offline   Reply With Quote
My 2001 900ss i.e. is having an issue. Help!! Ranas Supersport 35 May 4th, 2011 1:21 am
900ss carb issue or maybe ignition issue park Supersport 11 Oct 4th, 2010 9:50 am
95 900ss choke linkage eac71 Supersport 5 Oct 1st, 2010 8:30 pm
Tacho Issue - 900SS FE Big Wig Supersport 13 May 3rd, 2008 6:21 pm
Help with 94 900ss/sp ignition issue duck996 Supersport 3 Jun 13th, 2006 12:00 pm
