Lots of suspension guides on Google. Here are some suggested settings from Sportrider magazine.
bikhttp://www.sportrider.com/suspension_settings/suspension/146_suggested_suspension_settings/ducati.html
The first thing you need to do is see if you can set the sag properly. This will tell you if you have the correct spring rates or not, in case the previous owner replaced the springs with stiffer ones for his weight. Beyond that, you should do some searches and learn all you can about preload, spring rates, and compression and rebound damping.
1997 900 SS/SP track bike
1998 900 SS/FE #299
