04 800 ss problems* - Ducati.ms - The Ultimate Ducati Forum
Graves Motorsports
Old Dec 12th, 2011, 11:15 pm   #1 (permalink)
04 800 ss problems*
Having troubles with the 800 ss turning on, the nuetral indicator light doesnt come on so nothing happens when i press the ignition, we tride holding down the clutch and pressing the ignition but nothing, also tried it in gear and still nothing. we were trying to push it and start it that way and it would sound for a second as if it was gona start but it didnt. then i got on and moved the shifter a little with my leg, held down the clutch pressed the ignition and it turned on, but the neutral light was still wouldnt come on. Im not sure what it could be as we turned it off to see if we could get it back up but it just stayed off.
Any help would be much appreciated!!
2004 800SS
MxCartel is offline   Reply With Quote
Old Dec 13th, 2011, 10:58 am   #2 (permalink)
rummaggio's Avatar
hard to tell from your description but it could be the sidestand switch. either clean contacts or remove it with a bypass.
https://www.tpoparts.com/cat093/inde...&product_id=96
2006 800ss
rummaggio is offline   Reply With Quote
748 problems scoobysnax22 Superbikes 7 Jun 28th, 2011 8:17 pm
Got the Ecu in and now other problems Yeller98ST2 Sport Touring 8 Nov 12th, 2010 11:23 pm
ST3 top end problems DarmahDude Sport Touring 15 Sep 14th, 2008 12:16 pm
a whole mess of problems..but i'm thinking the problems are from one source 1998duck Superbikes 7 Sep 8th, 2008 4:17 pm
problems with my 748 r tobbe748 Superbikes 0 Aug 9th, 2007 1:52 pm
