Engine case repair - Ducati.ms - The Ultimate Ducati Forum
Graves Motorsports
Old Dec 10th, 2011, 11:13 am   #1 (permalink)
ian996's Avatar
Engine case repair
I acquired an 05 DS 1000 engine complete with a cracked/ broken front engine mount on thr left side crank case. I removed both cylinders so I could get access to the crack for a weld repair. Any opinion on welding up the crack without splitting the cases? The crack is actually more than just a crack the entire upper half of the mount is broken away so it can be beveled back for a decent weld.
[SIGPIC][/SIGPIC]
ian996 is offline   Reply With Quote
Old Dec 11th, 2011, 10:52 am   #2 (permalink)
This is going to be tricky to do well. Find a real expert in TIG welding. Spend a lot of time cleaning the weld area, especially down in the crack area. Al welding is very sensitive to contamination. Pre-heat the case as much as possible to minimize heat stresses and burn off contaminents. Good luck!
boosted_sled is offline   Reply With Quote
Old Dec 11th, 2011, 10:55 am   #3 (permalink)
Any photos please? Hard to say without seeing the crack itself?
Old Dec 11th, 2011, 2:58 pm   #4 (permalink)
ian996's Avatar
here are 3 shots of the damaged engine mount as you can see this is more than a crack and is probably easier to make a quality repair. I think the broken piece can be beveled to create decent "V" for welding... but then again I am not a welder. The dark grey material on the case is the remains of the epoxy repair from the previous owner.
Engine case repair-dsc01505.jpg   Engine case repair-dsc01506.jpg   Engine case repair-dsc01507.jpg
[SIGPIC][/SIGPIC]
Old Dec 12th, 2011, 2:46 am   #5 (permalink)
cs363's Avatar
Images: 2
Off topic a little, but just being nosey - how did they manage to crack the case there, was it from being in a crash and had crash bungs fitted or something else?
2005 Ducati SS1000DS Senna Gray
DP Carbon Exhaust*DP Air Filter Kit*MRA Dark Screen*ASV F3 Levers*Kaemna Seat Cowl*Tail Tidy*Hinson Slipper Clutch*Wave Discs*Modified Ohlins Shock*Race Tech Kitted Forks*Smoke LED Tail Light*Clear Indicators*Carbon for Africa!*Rizoma/STM/Oberon Red Anodised Bling Parts
1980 Honda CBX1000A Black
Kerker 6 into 2 system*Ohlins Piggybacks*Race Tech Kitted Forks*Telefix Fork Brace*Dyna Coils
cs363 is offline   Reply With Quote
75' 860 engine repair Kuma Vintage 2 Sep 25th, 2011 4:34 pm
ST3 engine generator case same as ST4? rstick1 Sport Touring 4 Feb 1st, 2011 1:36 pm
916 engine case same as 996? DucatiScotty Superbikes 3 Nov 20th, 2010 6:35 pm
250cc narrow case /350cc wide case engine brackets mike shannon Vintage 5 Apr 9th, 2010 5:10 pm
Need left side engine cover for my 996, not engine case crat996 Parts and Accessories 1 Feb 11th, 2010 1:49 am
