High Compression Heads - Ducati.ms - The Ultimate Ducati Forum
Old Dec 3rd, 2011, 10:57 pm   #1 (permalink)
Images: 3
Talking High Compression Heads
Who here has swapped out their factory heads on a 900ss?
What Compression Ratio (CR) did you reach?
How much did you spend?
What brand of Heads?
What was the end result?
Looking to swap mine this winter. Trying to get the most performance/dollar. I will be doing the work myself. '01 900ss Full Arrow Exhaust. Stock ECU...ya ya I know....stock ECU...flash and dyno tune coming soon..intake mod..15/43 renthal, gold 520 DID chain
Officer Bagels is offline   Reply With Quote
Old Dec 4th, 2011, 3:35 am   #2 (permalink)
herrgray's Avatar
Images: 18
Hi,
Ah, ok.... so your a two-stroke guy
On four-stroke motors to increase the compression you swap out the pistons... HC pistons are made by Pistal,Feracci(Wiesco) and JC. They cost between 300 and 600 dollars. Ratio is 11 to 13:1, though I would not go higher than 11:1 on a street bike running pump gas.
Gray
herrgray is offline   Reply With Quote
Old Dec 4th, 2011, 8:54 am   #3 (permalink)
1fast750ss's Avatar
There are several other Ducati's you can swap the heads on, however the 900SS isn't one of them, as the bolt spacing is unique from the others. As Gray said, HiComp pistons(or BBkit) would be the way to go. I would recommend an oversize oil cooler if you do this though.
As far as heads are concerned, the 900SS responds well to increased air, so porting with bigger valves is the way to go.
You have decent cams in the '01 SS, and would work well with a BBkit; and IIRC, adjustable cam pulleys. So cam timing would be essential.
Otherwise, if you just added the HiComp pistons, I would find a set of ST2 cams out there. They would be a great add on if you plan on keeping the peak HP higher up in the rev range.
Brian C.
'01 BCM 795SS / Track Toy
'03 999 w/50mm termi, S cams, BST wheels / daily commuter?
www.podiumracing.com
Maker of fine Ducati performance Parts and Accessories
1fast750ss is offline   Reply With Quote
Old Dec 4th, 2011, 4:59 pm   #4 (permalink)
VTGPDUC's Avatar
Originally Posted by 1fast750ss View Post
there are several other ducati's you can swap the heads on, however the 900ss isn't one of them, as the bolt spacing is unique from the others. As gray said, hicomp pistons(or bbkit) would be the way to go. I would recommend an oversize oil cooler if you do this though.
As far as heads are concerned, the 900ss responds well to increased air, so porting with bigger valves is the way to go.
You have decent cams in the '01 ss, and would work well with a bbkit; and iirc, adjustable cam pulleys. So cam timing would be essential.
Otherwise, if you just added the hicomp pistons, i would find a set of st2 cams out there. They would be a great add on if you plan on keeping the peak hp higher up in the rev range.
+1
2006 749S (resurrected)
1995 900SSSP/track bike
2001 750SS/"rain bike"
1975 CB400F/Yoshima
1996 CR250R
2005 CR85R (for sale, still)
1971 Bultaco-project
2000 Z50R
VTGPDUC is offline   Reply With Quote
Compression test too high? TheX Superbikes 17 Jul 14th, 2011 8:43 pm
Max Compression & Milling Heads 998Robbie Superbikes 3 Nov 11th, 2009 5:11 pm
High Compression Piston info PLEASE.... 08hyper HyperMotard 11 Dec 1st, 2007 9:44 am
High Compression Pistons HYPRmoTARD HyperMotard 5 Nov 12th, 2007 10:11 pm
