Dec 2nd, 2011, 2:34 pm
Dimensions of 99- shock?
I'm looking to buy a shock from another member. It is uncertain if the shock in question came off a carbie or fuel injected bike. Dimension given for center of eye to eye is is 365mm (14 3/8"). If the length doesn't help is there a visual design difference between the two? Thanks.
Dec 3rd, 2011, 12:57 pm
There is about an 8mm difference between the carbie and FI units. It does seem a bit long though.
I just checked my FI shock I have on the shelf and it shows about 337mm(preload all out). My Penske on my track bike is measuring at 350mm, and that's adjustable ride height as far out as it should go.
If I were in the market, I would look for a 1000DS rear shock as it has adjustable ride height.
Brian C.
'01 BCM 795SS / Track Toy
'03 999 w/50mm termi, S cams, BST wheels / daily commuter?
www.podiumracing.com
Maker of fine Ducati performance Parts and Accessories
Dec 3rd, 2011, 1:53 pm
IIRC the Fuelies have a knurled adjuster on the piggyback. If it is an OHlins you can rebuild them to get 10mm more height if it's a carbie spec vs a fuelie spec shock. Getting one with ride height adjustment is the way to go. Just remember your chain tension will be different if you add height. I have a stock 3way of an SP for sale if interested (revalved by B. Meyers) NOT height adjustable.
2006 749S (resurrected)
1995 900SSSP/track bike
2001 750SS/"rain bike"
1975 CB400F/Yoshima
1996 CR250R
2005 CR85R (for sale, still)
1971 Bultaco-project
2000 Z50R
Dec 3rd, 2011, 3:47 pm
Have a look on the top of the shock, it should have an ID number either cast or stamped into it. It'll be something like DU235 or similar. (or if not a Ducati shock it could have a different prefix...)
Post the number up and either myself or somebody else on here will be able to identify it for you.
2005 Ducati SS1000DS Senna Gray
DP Carbon Exhaust*DP Air Filter Kit*MRA Dark Screen*ASV F3 Levers*Kaemna Seat Cowl*Tail Tidy*Hinson Slipper Clutch*Wave Discs*Modified Ohlins Shock*Race Tech Kitted Forks*Smoke LED Tail Light*Clear Indicators*Carbon for Africa!*Rizoma/STM/Oberon Red Anodised Bling Parts
1980 Honda CBX1000A Black
Kerker 6 into 2 system*Ohlins Piggybacks*Race Tech Kitted Forks*Telefix Fork Brace*Dyna Coils
Dec 5th, 2011, 9:47 am
I just replaced the stock shock on my '91 SS and eye to eye the shock was 13".
'04 ST3
'91 900SS
'93 888 SPO
Dec 5th, 2011, 3:57 pm
shock
thanks for the info.
