Fixed tensioner assembly, (belt roller bearing) - Ducati.ms - The Ultimate Ducati Forum
Old Dec 1st, 2011, 12:38 pm   #1 (permalink)
LeoLegend's Avatar
the part number is 451.1.025.1a
It's the "third" bearing that guides the belts on the 900SS
Ducati lists it as a $121 part. Anyone know where I can get this bearing? Or anyone know the size so I don't have to buy the overpriced Ducati one?
Thanks!
LeoLegend is offline   Reply With Quote
Old Dec 1st, 2011, 2:22 pm   #2 (permalink)
LeoLegend's Avatar
I've found two part numbers
45120211A -- later models
45110251A--- older
They look like the same part. Are the two bearings the same for the older and newer models?
Old Dec 1st, 2011, 2:31 pm   #3 (permalink)
rummaggio's Avatar
I think they are of German decent, probably SKF. If you take it off, with a few measurements, a cross replacement can be found. Some searching on the Monster forums shows a different Ducati part for that bearing, so I would hesitate to confirm this suggestion of SKF cross (others around these parts can confirm/deny.)
SKF 6201-2RS L
However, here is a source for the original part number at $53
Fixed tensioner assembly. FIXED TENSIONER 1100 MTS/07.. TIMING (Quantity Required: 2); TIMING SYSTEM (Quantity Required: 2) for 2001 Ducati Monster 750 (451.2.021.1A)
good luck
2006 800ss
rummaggio is offline   Reply With Quote
Old Dec 1st, 2011, 2:43 pm   #4 (permalink)
Check your air pressure!!!
va duc's Avatar
Images: 12
Try here, I bought a complete set of cam tension replacement bearings from them.
Stein-Dinse Shop - Catalog - Ducati
AMA Member
1998 Silver ST2$
Eastern Virginia, USA
Old Dec 1st, 2011, 8:28 pm   #5 (permalink)
LeoLegend's Avatar
$50+ dollars just seems insane for a single bearing. I've searched and searched and I guess it's a custom size because no one has found a cross reference.
Old Dec 2nd, 2011, 9:50 am   #6 (permalink)
rummaggio's Avatar
I just took the covers off my 2006 800ss and looked at the bearing. Stamped on the side is 6201 2RS2, with the help of a magnifying glass and light (camera helped too..) A source for these lovely bearings http://www.vxb.com/page/bearings/PRO...FWsZQgodtWxCmw about $10 each. A quick call to them will clarify the meaning of the additional 2 at the end.
and a photo of the 800ss.
2006 800ss
Old Dec 2nd, 2011, 3:08 pm   #7 (permalink)
LeoLegend's Avatar
Originally Posted by rummaggio View Post
I just took the covers off my 2006 800ss and looked at the bearing. Stamped on the side is 6201 2RS2, with the help of a magnifying glass and light (camera helped too..) A source for these lovely bearings 10 Bearing 6201-2RS 12x32x10 Sealed Ball Bearings about $10 each. A quick call to them will clarify the meaning of the additional 2 at the end.
Thanks rummaggio, however I'm looking for the "other" bearing, ie. the fixed tensioner assembly in the parts catalog. It's the one directly across from the bearing you posted.
Old Dec 2nd, 2011, 3:30 pm   #8 (permalink)
rummaggio's Avatar
whoops, thought I crossed it correctly.
Went back to look at that and could not see any numbers on the side as with the 6201. This is interesting and I will continue to look around as well.
*Did some more research. It seems this may be a water pump bearing as indicated by some other threads. Here are some dimensions for an SKF model which has been referenced (SKF 367073A)
/N A C S2 S1 D D2 D1 K L F Dw DWl G M WEIGHT
367073A 49 23 18 3.5 12.738 M8*1 12.5 24 22 29 4.763*12 10 15.92
Searching for water pump bearings comes up with numerous types, not one in particular to a threaded shaft as used by Ducati.
http://www.alibaba.com/product-gs/28..._Bearings.html
Still a mystery, but will continue looking around.
This part number has also shown up (037029350)
2006 800ss
Old Dec 3rd, 2011, 9:46 am   #9 (permalink)
tempest411's Avatar
I've looked for this bearing myself in the past, and besides not finding anything, I've come across comments from others much more astute than most of us that have found this bearing is specific to this application. That being said, it certainly would be possible to get something close and then machine the appropriate mounting post and outer sleeve to give it the exact specifications required size-wise. As long as you used something that was suitable for the RPMs intended it would probably work. But as I am not a mechanical engineer and can't crunch the numbers to back up my theory, I just bought the factory pieces. I paid $73.00/each. The cost of failure was just too high.
tempest411 is offline   Reply With Quote
Old Dec 3rd, 2011, 4:19 pm   #10 (permalink)
LeoLegend's Avatar
Figured as such, thanks for all the research, I'm doing some work for a friend so I was trying to find budget options for him. I found the pair for $106 from ducati omaha.
Cam belt tensioner bearing question ZDM Superbikes 15 Nov 30th, 2011 8:50 pm
Cam Belt Tensioner Bearing Failure Ken Sport Touring 24 Nov 25th, 2011 1:05 pm
Belt Tensioner Bearing Removal M5zealot Supersport 8 Oct 21st, 2011 8:52 pm
RE: Replacing Belt Tensioner Bearing on ST3 MAZDuc Sport Touring 8 Mar 8th, 2010 1:54 pm
999 Timing Tensioner Roller Bearing Replacement mplspilot Superbikes 1 Sep 5th, 2006 8:07 pm
