Mine are done that way. Sound is good if you're on a budget; but it sounds like you're on a budget. It rattles and sounds kinda ratty IMO, but at e same time I also think it bests stock. But only slightly. The volume is there but lacks quality. Recommendation...save up for real pipes.
www.ducati-owners-group.com
