SS1000DS intake mods? - Ducati.ms - The Ultimate Ducati Forum
Graves Motorsports
Old Nov 24th, 2011, 10:01 am   #1 (permalink)
bruce19's Avatar
Just wondering what intake mods have been done. I tried finding stock air filters from K&N and BMC and haven't come up with anything.
bruce19
'05 SS1000DS
'03 Audi A4 Avant
'05 MASI Gran Criterium S
bruce19 is online now   Reply With Quote
Old Nov 24th, 2011, 10:28 am   #2 (permalink)
Ritlee's Avatar
Might read this forum prior to trying to mod your airbox.Airbox Resonance
'99 750SS
'07 Sportster 1200(sold)
'81 Honda CB750C (sold)
US Army Reserves, 14 years and counting
Ritlee is offline   Reply With Quote
Old Nov 24th, 2011, 10:55 am   #3 (permalink)
bruce19's Avatar
Thanks. I couldn't find anything when I searched.
bruce19
'05 SS1000DS
'03 Audi A4 Avant
Old Nov 24th, 2011, 11:14 am   #4 (permalink)
galaxy's Avatar
Images: 27
K&N makes a filter for the stock air box.
www.ducati-owners-group.com
galaxy is offline   Reply With Quote
Old Nov 24th, 2011, 12:27 pm   #5 (permalink)
Lifetime Premium
YellowDuck's Avatar
Theory is all well and good, but there are *plenty* of data showing that the DS1000 engine responds very positively to intake mods, as all 2V air cooled ducs seem to do.
Simplest approach on the SS is to just open the entire top of the airbox, exposing the entire filter area to open air, as with the DP air filter kit. Loss of resonance? Who cares? there is more torque everywhere, and no one who does this ever complains about "loss of throttle response". The SS won't even need remapping if you do this.
BikeBoy.org - 1000DS SS ie: Base runs, Mufflers, etc
That's a pretty good gain for basically just cutting a big whole in the airbox!
What is less clear is how much additional benefit you can get from going to a velocity stack / pod filter setup like this one:
Waspworks Power Up Kits
It comes with a pre-mapped PCIII. A lot of us Sport Classic guys have these and like them, but I don't think Greg ever put a kit together specifically for the SS.
There are also the TPO Beast and Beast-R intack stack / pod filter kits for the DS1000, but again, I am not sure if they offer it for the SS or not.
YellowDuck is offline   Reply With Quote
Old Nov 25th, 2011, 12:44 am   #6 (permalink)
cs363's Avatar
Images: 2
Agreed - and it should be pointed out that the article quoted by Ritlee earlier refers to Superbike intake systems which are quite different to the Supersport.
The dyno print out for my 1000SS (with DP slip on's and DP air filter kit) was almost identical to the one shown above, the bike feels stronger everywhere in the rev range and pulls cleaner off idle than when it was stock.
2005 Ducati SS1000DS Senna Gray
DP Carbon Exhaust*DP Air Filter Kit*MRA Dark Screen*ASV F3 Levers*Kaemna Seat Cowl*Tail Tidy*Hinson Slipper Clutch*Wave Discs*Modified Ohlins Shock*Race Tech Kitted Forks*Smoke LED Tail Light*Clear Indicators*Carbon for Africa!*Rizoma/STM/Oberon Red Anodised Bling Parts
1980 Honda CBX1000A Black
Kerker 6 into 2 system*Ohlins Piggybacks*Race Tech Kitted Forks*Telefix Fork Brace*Dyna Coils
cs363 is offline   Reply With Quote
Old Nov 25th, 2011, 3:42 pm   #7 (permalink)
bruce19's Avatar
Has anyone tried a Power Commander with the DS motor?
bruce19
'05 SS1000DS
'03 Audi A4 Avant
Old Nov 25th, 2011, 3:53 pm   #8 (permalink)
cs363's Avatar
Images: 2
That was in my plan, or use the DP ECU I have, but the bike ran perfectly on the stock ECU - mind you, that is in the Southern Hemisphere so different elevation/humidity etc and also I think our gas is a bit more potent...
Old Nov 26th, 2011, 6:54 am   #9 (permalink)
Lifetime Premium
YellowDuck's Avatar
Lots of Sport Classic guys use them. The trick is that they don't work with the stock ECU, since it runs in closed loop (lambda sensor) and the ECU will just override whatever the PCIII does. However, with the DP ECU the lambda sensor signal is not used, and the PCIII works in the normal way.
Old Nov 26th, 2011, 3:00 pm   #10 (permalink)
bruce19's Avatar
Any idea what kind of results are obtained and if it's cost effective?
bruce19
'05 SS1000DS
'03 Audi A4 Avant
Air Intake Mods Sputniks StreetFighter 16 Aug 31st, 2011 3:53 pm
Hyper air intake mods/filters etc SweFin796 HyperMotard 9 Mar 28th, 2011 6:10 pm
2009 Monster 1100 - MUST SEE Mods/Mods/Mods 53Monster1100 Bikes 4 Nov 28th, 2010 8:26 pm
Pics of intake mods? SquireSCA StreetFighter 15 Feb 14th, 2010 1:21 pm
Intake and Fuel Injection/Ignition Mods - Part 1 dukepilot HyperMotard 98 Sep 26th, 2008 4:00 am
