Whats wrong with my squish? - Ducati.ms - The Ultimate Ducati Forum
Old Nov 20th, 2011, 2:41 pm   #1 (permalink)
1995 900ss/cr. I put my new JE 92mm high compression pistons on and went to set the squish. With NO spacers, I can only get it down to .05". I think it should be .04" right? I just did it again with the stock pistons and it is also .05".
Am I measuring wrong? I'm using rosin core solder,btw. Do I push it all the way to the lip and measure there? I didn't think so. I'm measuring at the outside of the taper. The inside of the taper is at .06" which I think reflects a good taper.
Any ideas are appreciated!
Ken
DucatiKen
'95 Ducati 900ss/cr Restoration Project
Follow my restoration: www.kensducati.blogspot.com
DucatiKen is offline   Reply With Quote
Old Nov 20th, 2011, 3:25 pm   #2 (permalink)
herrgray's Avatar
Images: 18
Hi,
I had the same problem with my 750. You will need to have 0.010" turned from the bottom of your cylinders. 0.040" or 1mm is correct squish.
you need to mesure to the outsid edge of the pistion...
Gray
herrgray is offline   Reply With Quote
Old Nov 22nd, 2011, 11:52 pm   #3 (permalink)
Wink
Paint! Argh! I was staring right at it thinking of getting them milled and then it smacked me in the forehead. I didn't mask off the base areas when I painted the cylinders and heads. I sanded the paint off and now it's perfect. Doh!
DucatiKen
what is squish? Viper463 Superbikes 37 Jan 22nd, 2011 11:35 am
Whats wrong with this picture? MrGixxerChic HyperMotard 27 Aug 17th, 2010 2:16 am
Whats wrong with me? bromike666 Superbikes 9 Nov 7th, 2008 8:46 am
i figured out whats wrong with the extreme heat coming off my bike CFlan423 Superbikes 13 Aug 3rd, 2008 11:19 am
Whats wrong with my 749s ?????? heeeelp!!! SennaDuc Superbikes 1 Aug 10th, 2007 3:11 pm
