How do I replace these O Rings - Ducati.ms - The Ultimate Ducati Forum
Graves MotorsportsMotorcycle.com Classifieds!
Motorcycle.com
Old Nov 19th, 2011, 2:40 pm   #1 (permalink)
Ritlee's Avatar
So I'm getting engine oil in my clutch fluid. I was told that the seals on the Clutch Control Rod are leaking causing the engine oil to get in there. I have the O rings in hand and was wondering if there's an easy way to get to them?
It's on my '99 750SSie w/ a wet clutch.
'99 750SS
'07 Sportster 1200(sold)
'81 Honda CB750C (sold)
US Army Reserves, 14 years and counting
Ritlee is offline   Reply With Quote
Old Nov 19th, 2011, 2:52 pm   #2 (permalink)
Check your air pressure!!!
va duc's Avatar
Images: 12
Drain the oil, remove the outer clutch cover, inner cover, springs, pressure plate and pull it out.
Easy as pie.
I believe you also have a problem with your slave cylinder seals also as oil should not get past those seals, you probably have both leaking in the vicinity of the counter shaft cover?
AMA Member
1998 Silver ST2$
Eastern Virginia, USA
Old Nov 19th, 2011, 4:03 pm   #3 (permalink)
Ritlee's Avatar
I was afraid i'd have to go at that rod from the clutch side , didn't wanna drain the oil.
That's a fear I have, and a probability. but if I'm replacing the seals in the slave @ $50, might as well spend $125 for an aftermarket piece that gives a lighter pull on the handle . But can't really afford the slave cylinder atm.
'99 750SS
Old Nov 19th, 2011, 4:50 pm   #4 (permalink)
Ritlee's Avatar
Ummm is it normal to pull the Clutch Control Rod out of the engine from the slave cylinder side??? 'cause ummm... I just did... thankfully I haven't dropped the oil, that is if it's ok to pull the rod out. Very easy I might add.
'99 750SS
Old Nov 19th, 2011, 6:47 pm   #5 (permalink)
BakonDuc's Avatar
If I remember my past reading correctly (and that's not always a good bet), the reason for pulling the shaft out the clutch side is that there is a little bushing that, in some cases, can become stuck onto the clutch-end of the pushrod so that it couldn't be pulled through from the slave cylinder end without some manipulations and gyrations to free it up first.
If yours pulled through from the left side without a problem, there ya go.
Bryan
1999 900 Supersport
1984 Moto Guzzi V65 SP
2004 KTM 625 SMC
BakonDuc is offline   Reply With Quote
Old Nov 19th, 2011, 7:00 pm   #6 (permalink)
va duc's Avatar
Images: 12
Bryan
I thought the same thing, that might just be for the dry clutches?
Even so, there is now way oil should be getting into the slave.
You can get one off ebay used for 40 or 50 bucks, or a new one for 129.
OBERON Ducati Clutch Slave Cylinder - Silver | eBay
Or just contact moto for what ever color you need.
AMA Member
1998 Silver ST2$
Old Nov 19th, 2011, 7:29 pm   #7 (permalink)
Ritlee's Avatar
Yeah that's actually the one I have my eye on, though I can get it locally for the same price including tax. The problem is, talking the wife in to letting me get it. Especially since it appears that I also need a chain, and a D.I.D. chain goes for about $180.
I just need to keep the bike running safely 'till march. I leave for the mid east for 12 months and will be able to afford all the necessary quality parts for the Duc.
'99 750SS
Old Nov 20th, 2011, 7:44 am   #8 (permalink)
Evoluzione?
These guys make a piston/seal kit for the stock slave for $30, if you don't want to spring for a whole new unit.
evoluzione cyclesports - ducati
D.I.D. 520ERV3 Heavy Duty Gold X'ring Race/Street Chain Sprocket Center
You can get DID ERV3 chains here for less than $180, even less if you buy one in a set with the sprockets (which you should do).
1997 900 SS/SP track bike
1998 900 SS/FE #299
Joe-B is offline   Reply With Quote
piston rings, where to buy m90daytona Superbikes 9 Oct 20th, 2009 10:55 pm
Puncture in rear tire on 08 MTS - plug or replace? Replace with? vikingarcher Multistrada 9 Aug 13th, 2008 8:00 pm
O-Rings for Push Rod (748) 748Rider Superbikes 12 Aug 4th, 2007 10:30 pm
916 hits 24K miles... Should I replace the rings? JEC Superbikes 10 Feb 20th, 2007 10:48 am
Replace piston rings at the same time as a piston 900FE_79 Ducati Motorcycle Chat 12 Nov 30th, 2006 10:17 am
