Stickers/Decals - Ducati.ms - The Ultimate Ducati Forum
Graves MotorsportsMotorcycle.com Classifieds!
Motorcycle.com
Old Nov 16th, 2011, 11:09 am   #1 (permalink)
jjvj23's Avatar
Exclamation Stickers/Decals
I have undertaken the challenge of repainting my new toy. I've never done it before so wish me luck. However in doing so I need some new decals.
So I have scoured the internet in search of the oem stickers for a 2001 750SS. I have finally found them! Before I order them though I would like some input.
First, please look over my order and make sure that I have all of the stickers that are for show, in other words I don't care as much about the sticker that tells me where I can hang my helmet, and second, is there anywhere you guys/gals know of that they may be cheaper?
My complete shopping list.
FUEL FILTER.
Stock Code: 425.4.008.1A
$20.94
LABEL. Sticker.
Stock Code: 433.1.170.1A
$0.41
*DUCATI* TRANSF. 750-900 SS/00. Sticker "DUCATI".
Stock Code: 435.1.030.1AA
$7.28
*DUCATI SS EI* TR. 750-900SS00. Sticker "Supersport" (YELLOW).
Stock Code: 436.1.030.1AB
$6.16
*DUCATI 750* LH TR. 750 SS/00. Sticker "DUCATI 750" (YELLOW).
Stock Code: 437.1.106.1AB
$26.82
*DESMODUE* TR. 750-900 SS/00. Sticker "DESMODUE" (YELLOW).
Stock Code: 437.1.108.1AB
$6.01
*DUCATI 750* RH TR. 750 SS/00. Sticker "DUCATI 750" (YELLOW).
Stock Code: 437.1.110.1AB
$26.82
WASHER.
Stock Code: 734305N01
$0.09
SCREW M5X22 SBE/04.
Stock Code: 777.5.039.8B
$0.21
PLUG SCREW.
Stock Code: 779.5.007.1A
$0.71
GASKET.
Stock Code: 791.1.015.1A
$9.85
RETAINER 750/900 SS/03.
Stock Code: 841.1.028.1A
$5.34
SEEGER RING. Gear Circlip tool.
Stock Code: 884.4.012.1A
$0.20
GASKET. O-Ring.
Stock Code: 886.4.011.1A
$10.13
SCREW.
Stock Code: 77350672B
$0.51
jjvj23 is offline   Reply With Quote
Old Nov 17th, 2011, 7:19 am   #2 (permalink)
Punch's Avatar
From your list of decals it looks like you have it right. I can't confirm the numbers as I don't have a 750 part number list.
The decals on our bikes comprise, upper and lower case letters as shown below
The "DUCATI" on the tank in front of the filler cap.
On left and rich sides of the fairing - "DUCATI", "Desmodue" and "750" or "900" depending on your bike.
On the rear seat cowl on both sides, it has "DUCATI SUPERSPORT i.e."
Painting - this is not for the faint hearted and whilst i learnt how to do it, there are some basic rules to follow. If you send me a personal message with your email address, I will send an article I wrote about doing it. Unfortunately the file size exceeds the limit allowed on this site.
Even if you don't send a PM, the basic rules are ...
The finished job can never be better than the preparation of the surface to be painted.
Cleanliness is a key to long lasting paint - I wear and frequently change/discard cheapo disposable plastic gloves from the supermarket.
Between each coat, use "wax and grease remover" to clean the surface and wipe over with tack cloth.
Don't wet the floor thinking it will keep dust down - this increases moisture content in the air and can stuff up the paint finish.
MAJOR MAJOR MAJOR - download the instructions from each paint supplier on how to use the paint. E.g. surface prep, time between coats, grade of sanding paper, ambient temperature etc. etc. Don't be daunted - it can be done at home.
Use a gravity feed spray gun.
Make sure your compressor has a water filter in the supply line to your spray gun.
Be patient and wait the recommended times for the temperature you are spraying in.
If you are doing what is known as clear over base (clear coat over a base colour) clear for amateurs like me is a tricky product to spray. It runs at the drop of a hat and sanding and polishing drips is a PITA.
I highly recommend a practice run on something else first so you can get used to how all the different coats spray, dry etc.
Have a look on youtube - thee are some brilliant vids on how to use a spray gun - distance from the piece to be painted, what to do at the end of a spray pass and much more.
Post some pics and I hope you are going to go yellow!
After i get a few other projects out of the way I am going to respray my whole bike and the CF in yellow, but pull the decals afterwards so where the decals were show thru to the CF.
Richard
PS - add to your signature where you are and what bike you have for future posts - makes it easier for those that maybe can help.
2001 900SSie
The more I learn, the more I realise how little I know.
There are a lot of experts in this world. Fortunately there are others who know what they are talking about!
Obsessed with bikes = Yes. Do I care = No
Punch is offline   Reply With Quote
Decals? Stickers? Sticky Supersport 12 Nov 21st, 2011 7:27 am
fs: ducati 999 testaretta decals and bayliss windscreen decals superbike-italia Parts and Accessories 0 Jan 17th, 2010 5:01 pm
fs: ducati badge gel decals and 916 decals superbike-italia Parts and Accessories 1 Jan 17th, 2010 4:56 pm
Stickers egrafx2006 Ducati Motorcycle Chat 9 Mar 20th, 2008 11:29 am
Clear cover to spray over decals / stickers kurtfriedrich Superbikes 5 Jan 30th, 2007 1:27 pm
