Clutch plates rust? - Ducati.ms - The Ultimate Ducati Forum
Graves MotorsportsMotorcycle.com Classifieds!
Motorcycle.com
Old Nov 15th, 2011, 12:34 pm   #1 (permalink)
DME3's Avatar
Clutch plates rust?
When I put my Superlight in gear and hold in the clutch I can't move the rear wheel. It seems as if the clutch isn't activated, but I can see the cluth move out when I pull the lever.
Could this be the clutch plates rusted to one another?
If so, what can I do to fix this?
The bike is stalled in a garage, but it is quite cold and humid in there. Same temperature as it is outside... cold and foggy the last couple of days. Bike hasn't started in about 2 months.
Or should I look somewhere else?
Ducati 900SL MK I n° 92 | Ducati 900SS '94 Trackbike
DME3 is offline   Reply With Quote
Old Nov 15th, 2011, 1:28 pm   #2 (permalink)
snlsmith's Avatar
Images: 4
What happens when it is in Neutral?
snlsmith is offline   Reply With Quote
Old Nov 16th, 2011, 1:16 am   #3 (permalink)
I got caught once - washed the bike then put it away damp. A couple of weeks later when I went to take it out for a ride it was fine in neutral but stalled as soon as I tried to put it in gear.
Clutch plates had stuck together. Just kept pumping the lever in and out and it freed itself. Others (I think) have taken the plates out then re-installed - but that takes too long.
I now go for a short ride after it's been washed.
1993 Ducati 900SS
1984 Honda VF1000RE
He was as lame as a duck. Not the metaphorical lame duck either, but a real duck that was actually lame. Maybe from stepping on a pebble and rolling an ankle.
TassieDave is offline   Reply With Quote
Old Nov 16th, 2011, 2:07 am   #4 (permalink)
Not being cocky, but: what ? If the plates are rusted together take it apart for inspection. It takes 10min (not too long I think)
me:
'76 Claus Bang
my girls:
'93 Ducati 900 Supersport
'76 Honda CB750 K6
bang76 is online now   Reply With Quote
Old Nov 16th, 2011, 2:41 am   #5 (permalink)
DME3's Avatar
No problems in neutral. TassieDave's story seems to fit my issue but the plates don't free themself by pumping the lever.
I'll get the plates out this weekend for cleaning and inspection.
First time fidling with the clutch, but according to the Haynes manual I don't need any sort of clutch tool to get the plates out.
Old Nov 16th, 2011, 2:51 am   #6 (permalink)
Fair call.
I suppose if you can see the pressure plate move, the cover is either off or it's an an open cover. And sitting idle for a couple of months is a bit different to a couple of weeks.
1993 Ducati 900SS
1984 Honda VF1000RE
Old Nov 16th, 2011, 3:44 am   #7 (permalink)
DME3's Avatar
Open cover indeed
I'll use a closed one for winter storage, hoping that will keep damp out.
Old Nov 16th, 2011, 6:47 am   #8 (permalink)
Punch's Avatar
Commenting on a few posts in one hit.
Pulling the clutch lever in just lifts the pressure plate. This simply takes the spring pressure off the driven and drive plates. So honestly this will not separate the plates at all. It, in normal practice, pulling the clutch lever lets the drive plates spin and the driven plates not be driven.
I know from experience that if, with my very open cover, the plates get wet from rain, they probably swell up and even when the lever is pulled in, there is not enough lift to separate the swollen (thicker) plates.
When we go on rides where the bike will be parked outside in the rain, I just put a plastic bag over the open cover to stop rain/water getting in.
A short ride normally fixes the problem, but at first neutral is almost impossible to find and when stopped in first gear with the lever pulled in, the clutch plates are still trying to push the bike.
I would not worry too much about it. Just take it for a ride to clear it out.
2001 900SSie
The more I learn, the more I realise how little I know.
There are a lot of experts in this world. Fortunately there are others who know what they are talking about!
Obsessed with bikes = Yes. Do I care = No
Punch is offline   Reply With Quote
Old Nov 16th, 2011, 8:10 am   #9 (permalink)
Lifetime Premium
YellowDuck's Avatar
I can think of lots of dangerous and exciting ways to fix this!
For example, try starting it in gear with the clutch lever pulled in and the brakes on hard. The starter motor may free it. Of course, if it doesn't work you are in for a ride. Anyway, that is what I did when it happened to my Jeep. How different could it be?
Or, put it on the rear stand, get it running in first, then pull in the clutch and use the rear brake to stop the rear wheel. Also incredibly stupid and dangerous. So why not give it a try? Should make for an entertaining post for the rest of us to read tomorrow.
Or, you could just be a pussy about it and pull the clutch pack out....
YellowDuck is offline   Reply With Quote
Old Nov 16th, 2011, 9:23 am   #10 (permalink)
DME3's Avatar
Open clutch cover and rust adroc StreetFighter 46 May 21st, 2010 2:10 am
Chain Rust Protection using gun rust inhibitor samman23 Ducati Motorcycle Chat 18 Oct 27th, 2007 12:25 am
999 rust on clutch safetyfish Superbikes 7 Aug 23rd, 2007 1:28 pm
