Solo Seat Mystery Bracket Search - Ducati.ms - The Ultimate Ducati Forum
Old Nov 10th, 2011, 1:10 am   #1 (permalink)
M5zealot's Avatar
I was able to source a Solo Seat but all brackets were missing. I was able to order all parts from my dealer and received 90% of them already. We can't seem to figure out what/where the "glassed in" bracket is. I have both front and rear seat brackets w/ appropriate rubber bumpers. The parts catalog does not seem to list or show the part the rear brackets bolt onto. (looking at 900SS FE solo seat diagram)
I'm pretty good w/ fiberglass but have zero talent in fabricating metal brackets. Can anyone shed some light on what this mystery part is? I'm assuming the FE seat already had them glassed in at the factory. BTW my seat seems to have had the rear bracketing because it's obvious they were pulled off or broke off leaving an imprint of where they were glassed to the seat. I at least have some reference exactly where to re- glass them if I can find them. Thanks
Euro spec 88 BMW Dinan M5
04 Audi A4 Cabrio
09 Aprilia Mana 850
95 900 SP - # 619 (custom red frame & black body work)
Still looking for the perfect 999R.
http://e28-535i.com/upload/sigduc_1.jpg
M5zealot is offline   Reply With Quote
Old Nov 10th, 2011, 8:27 am   #2 (permalink)
I have a Sharkskinz and an FE solo seat and I'd like to help, but your question isn't clear. Your new seat seems to have all the parts as the stock seat, except for the front mounting brackets, which use the same bolt holes as the seat pad.
1997 900 SS/SP track bike
1998 900 SS/FE #299
Joe-B is offline   Reply With Quote
Old Nov 10th, 2011, 8:35 am   #3 (permalink)
DME3's Avatar
The older SL solo seats don't have the mounts that bolt on the rear brackets
Ducati 900SL MK I n° 92 | Ducati 900SS '94 Trackbike
DME3 is offline   Reply With Quote
Old Nov 10th, 2011, 8:44 am   #4 (permalink)
M5zealot's Avatar
Sorry for not being clear. I think I confused you by posting two different seats that are not mine. (too lazy to take pics today) I need the "bracket" the rear supporting brackets bolt onto. This part is glassed/fuse to the seat itself. So if you look at the top pic w/ four brackets....if you unbolt the rear supporting brackets you will see a part fused/glassed to the seat. That is the part we are trying to identify/order. Hope that is clear
04 Audi A4 Cabrio
09 Aprilia Mana 850
Old Nov 10th, 2011, 8:46 am   #5 (permalink)
M5zealot's Avatar
I know. I wanted to go the FE route since it has 4 supporting brackets instead of just two.
My seat had all four brackets at one time. I didn't complain to the seller because he threw in mint condition cushions!
04 Audi A4 Cabrio
09 Aprilia Mana 850
Old Nov 10th, 2011, 9:56 am   #6 (permalink)
DME3's Avatar
I don't think you'll find that part individually since it came with the seat unit attached to it...
If it's not in the part manual as a single part, I think you'll need to DIY.
But do you need the rear support? I'm running my Superlight without them
I have an extra seat which does has them, but I don't see how those have a purpose.
edit: be sure to post some pic's of your bike with the solo seat!
Old Nov 10th, 2011, 10:05 am   #7 (permalink)
I'm pretty sure the fused-in bracket came with the cowl and wasn't available separately.
Not that it would be a big deal to omit them. The front seat brackets are more than enough support for the pad which is where all the weight sits. The cracked cowls that get mentioned often are the ones that likely don't have any support brackets at all. It you need the rear brackets for alignment, I did see where one chap had used a pair of thick rubber tubes, cut and placed around the frame near the tail light. Worked well too.
Flash Harry is offline   Reply With Quote
Old Nov 10th, 2011, 10:59 am   #8 (permalink)
M5zealot's Avatar
Thanks guys! Appreciate your input. I weight about 160 lbs so I think the front brackets should be ok. I only wanted the rear ones because I developed a reliance on my "basket handle!" It's very handy to grab onto it when putting my bike on a rear stand. I figured with it gone in the conversion, if I grab on to the solo tail w/ no rear brackets I could cause undo stress and eventually crack it. I'll post pics when the project is done. I'm doing all the prepping and painting.
04 Audi A4 Cabrio
09 Aprilia Mana 850
Old Nov 10th, 2011, 1:25 pm   #9 (permalink)
DME3's Avatar
You won't crack it putting it on a paddock stand
It needs a bit of practice though. I lean my bike a bit on the hip and hang on to the upper upholstery (the back support leather thingy) when I put it on the stand.
If you want, I can take a picture of how my solo seat looks with the rear brackets. That way you'll have an idea how to make your own if you'd ever want to.
Old Nov 10th, 2011, 4:14 pm   #10 (permalink)
Randy, I'll check when I can get to removing my FE seat. I sure love the 4 Dzus fasteners on my SP track bike solo seat, that I bought from Motowheels .
1998 900 SS/FE #299
Amazing Solo Seat Bracket - In German! M5zealot Supersport 12 Oct 28th, 2011 5:18 am
Sport Classic custom solo seat cowl, sport tank and biposto seat roggt1000 Parts and Accessories 0 Jul 15th, 2010 8:15 am
Solo Seat Help Big Wig Supersport 22 Mar 2nd, 2008 7:56 pm
ease of swap: Dual Seat - Solo Seat SS/SP 96SP Supersport 7 Dec 16th, 2007 8:10 pm
06 SS solo seat daflemdog Supersport 2 Sep 22nd, 2006 5:13 pm
