Are all 41mm FCR created equal? - Ducati.ms - The Ultimate Ducati Forum
SportbikeTrackGearMotorcycle.com Classifieds!Motorcycle.com
Old Nov 7th, 2011, 6:29 pm   #1 (permalink)
barnapkin's Avatar
I have a set of 39mm (side-by-side) FCR carbs on my 900 track bike. Bike runs well, but would like to run the split carbs. The the shorter intakes will give me some additional top end. With 15/38 gearing my GPS sez it pulls a consistent 129-130 with my fat ass. I've already purchased the malosi intakes.
I see a lot of 41mm FCR carbs from dirt bikes out there on ebay. Is it possible to get two and rejet them vs. paying $1K for NIB factory set?
Are the dirtbike FCRs the same as the FCRs you see for sale for ducks?
'03 Moto Guzzi V11 Lemans
'98 900 FE (#46)
'97 750M (904cc)
'93 900SS (track bike)
barnapkin is offline   Reply With Quote
Old Nov 8th, 2011, 3:24 am   #2 (permalink)
Iconic944ss's Avatar
I wondered the same thing but, all the dirt bike FCR's I saw all had Throttle Position Sensor (TPS) equipment on them so I decided against trying them.
I was going to say its possible to cut down a set of long OEM inlet tubes but you have the Malossi's already so, good for you!
Yamaha TRX850 also have an upgrade route of FCR's - I got a pair cheap via Ebay UK but the spacing is different, I've not know anyone use split singles on them sadly.
I've also vaguely remember a company converting dual FCR's to split single's and it was VERY expensive, like $300+
Good luck - Frank
Currrent Bikes:
1993 944SS: Everything has been fiddled with
2001 ST4S: The new kid on the block
2001 Aprilia Falco: Ohlins forks, Oz wheels = Stealth Fighter.
My 900ss Resource: http://900ss.proboards.com/
Iconic944ss is offline   Reply With Quote
Old Nov 8th, 2011, 3:35 am   #3 (permalink)
the probleme is if you buy two FCR carbs from a dirt bike you will have two carbs that are designed for vertical cilinders.
if you buy the kit you will have a carb for a vertical cilinder and one for the horizontal cilinder.
it possible to set one of the carbs up for the horizontal cilinder but you gonna have to look good how you place it so that the bowl is not overflowing.
henk!!!
henk155 is offline   Reply With Quote
Old Nov 8th, 2011, 7:27 pm   #4 (permalink)
A cheaper alternative could be using Mikuni TM41 Pro flatsides. The low end and midrange response isn't quite as silky as the FCR's but they do work well.
The only real downside is the float level on the horiz. cyl. has to be low to cope with the mounting angle [to keep from overflowing] and if you are producing lots of power you run the risk of going lean if the fuel flow can't keep up. I ran them on my 900 for about 6 season with good results though.
wdietz186 is offline   Reply With Quote
WTB: O2 sensor for 06 sport 1000 or equal jshea Parts and Accessories 1 Aug 16th, 2010 7:01 pm
I think I created An animal! sargeott HyperMotard 4 Jul 10th, 2010 11:56 am
Are all Termi's created equal? Duc_Dogger Superbikes 2 Jun 25th, 2009 11:56 pm
Quietly created davemcqueen Sport Classic 9 Dec 31st, 2008 1:36 pm
Equal (in track times) to the Sport Classic Greg_S Sport Classic 3 Mar 9th, 2007 8:33 am
