Oct 31st, 2011, 9:05 pm
89-90 900 clutch question
hello all,
Trying to troubleshoot an early clutch without the pushrod through the motor.
Not sure on stack height as it was put back together with more than enough plates lying around so it has been assembled with a stack height of 38mm.
We are having trouble with the clutch engagement. Seems to be a nice lever but stalls when putting into gear.....
I haven't seen as it is a freinds whio has it all back together after splitting for case repair after an accident.
Cheers in advance.
Nick.
Corse1
03 ST4s ABS (2006 -)
07 Tuono 1000R (2011 -)
03 Aprilia Tuono RSV 1000 Racing (2011-2011 Crashed)
06 1050 Speed triple (2009-2011)
Nov 1st, 2011, 10:19 pm
Hmmmm. Did the clutch plates go back into the bike in the right order?
Got stranded by one of these in Rakia once.
The thrust bearing on these things can be problematic. You need to bleed and bleed again to get the air out of the sytem. Don't rely on the bleed valve, take the cover off and do it manually with your thumb, obviously making sure that the bearing doesnt pop out.
You might not find too much help here, the 89-90 wasnt sold in the US. NZ & Auz seem to have got half the worlds supply! Guinea pigs cos we can fix stuff maybe?
Hamish, ex Britten Motorcycle Company
'89 900SS: '95 cases, close ratio box, '95 front end with 5 spoke marchesini, '95 tank with paso filler, carbon Supermono fairing, Projector beam headlights, billet rearsets, carbon 955 Corsa tail, 944cc Vee Two kit, 916 SPS clutch, DP Cams, ported heads, 41mm FCRs, Spaghetti pipes with carbon cans, Ohlins shock, 1000SSie swingarm & marchesini rear wheel. Currently in motorbike hospital after Earthquake
Plus
'95 900SS/SP: Bought May '11.
07 Aprilia Tuono: Bought Aug '11.
'06 GSX-R1000: Full Ohlins. Madness!! Sold Feb 11, written off same day!
'03 Monster 620ie: Sold Dec '10
'00 Aprilia Mille R: Sold Oct '10. Gone but never forgotten
Nov 1st, 2011, 11:03 pm
Thanks...we found the problem,....stack height is supposed to be 33mm
How do you like the Tuono...
Corse1
Nov 2nd, 2011, 3:12 am
Good job!
Had a 2000 RSV Mille R (loved that bike!) and thought the '07 Tuono might be better, more top endy. And it is... but, have to say I just don't get on with it.  The 'old' motor was just so massively wonderfully raw. Esp with the Akra Ti Aprilia racing pipe. (Or maybe I just prefer sportsbikes.) So back on Trade Me it'll be going.
I'm a Ducati man, but having worked for Britten I have a huge soft spot for 60* watercooled V-Twins.So, if you know anyone with a 07-> RSVR Factory, (or even a special Duke 998/999) might be keen on a trade.
Cheers
H
Plus
