ohlin forks for 900ss 93 - Ducati.ms - The Ultimate Ducati Forum
post #1 of 18 (permalink) Old Sep 7th, 2011, 4:42 am Thread Starter
Hi, started a massive rebuild on a 93 900 ss and would like to change forks over to Ohlins, any easy way of doing it? Thanks
sharpie is offline
post #2 of 18 (permalink) Old Sep 7th, 2011, 6:09 am
DME3's Avatar
Maybe the old 888 Ohlins are a straight fit. The triple clamps from an 888 seem to be the same as the 900SS (but then again, so does the M900 triples and they have a different ofset).
You need other triples or have the stock ones adjusted to use a more recent Ohlins fork.
Ducati 900SL MK I n 92 | Ducati 900SS '94 Trackbike
DME3 is offline
post #3 of 18 (permalink) Old Sep 7th, 2011, 9:00 am
ian996's Avatar
ohlins FG 845 forks are the correct diameter 50mm for the 900. They will bolt up to the stock triples.
Current Rides
2012 Multistrada 1200 S, 2000 996 mono track only, 1997 900 SS track only, 2002 BMW R1100S, 1970 Triumph Bonneville (restoration project)
ian996 is offline
post #4 of 18 (permalink) Old Sep 8th, 2011, 5:12 am
Iconic944ss's Avatar
I'll keep an eye on this as I'm planning to do the same (at some point) - my Ohlins are currently on my Falco but came from an RSVR - I'm hoping to use the whole Aprilia yolk and find suitable bearings OR I seem to remember seeing that the 900ss stem can be pressed in different yolks.
From my poor memory my Ohlins are 53mm top diameter.
This has been done before but I think with 50mm Ohlins as stated - I seem to remember cyclecat offered an upper yolk to do the proper conversion.
Good luck - Frank
PS - Get some 4 pad calipers from an RSVR or 749, you'll love the improvement!
- My Location: North East, United Kingdom (but wish it was the Alps!)
Currrent Bikes:
1993 944SS: Everything has been fiddled with
2001 ST4S: The new kid on the block
2001 Aprilia Falco: Ohlins forks, Oz wheels = Stealth Fighter.
My 900ss Resource: http://900ss.proboards.com/
Iconic944ss is offline
post #5 of 18 (permalink) Old Sep 8th, 2011, 5:18 am
Some good info here:
Ohlins forks on SS?
Currrent Bikes:
post #6 of 18 (permalink) Old Sep 8th, 2011, 5:34 am
If you have plenty of money, nothing is impossible. I do recommend doing the research first though as there are a lot of hidden costs. With my recent fork rebuild on a '94, I ended up going down the Race Tech road rather than the Ohlins even though I was able to access some cheap forks. It was definitely worth doing anyway.
Flash Harry is offline
post #7 of 18 (permalink) Old Sep 8th, 2011, 5:40 am
By coincidence, I'm currently working on my engine and getting the bike painted at the same time. If you need a hand with anything, give me a shout. I'm probably not that far away if you're NOR?
post #8 of 18 (permalink) Old Sep 8th, 2011, 10:20 am
galaxy's Avatar
Images: 27
I'm gonna chime in here a little because I have found myself considering an older SS as a project bike and have similar thoughts. I'll start with this...
Ducati Supersport Complete Triple Assembly - Includes Upper and Lower Triple Clamps - Fits all super: SpeedyMoto Ducati
Is this set-up a bolt on application for the pre-'98 SS's?? If so, wouldn't this simply allow you to add forks, fender, brakes, wheels, etc; a bolt on swap-over if you will from any SBK with 53mm forks...which if I recall, would work with forks off of almost anything: 749/999/848/1098/etc??
I've been trying to follow discussions on adding late model wheels to older SS's and this has it's challenges as well. Seems going this route, albeit quite pricey, would eliminate some headache??
I don't know that I'm correct about these tripples making the rest of the project a bolt on application, but if I am this could be the bulk of your investment. There's always great SBK forks and wheels floating around for sale used at some really great deals sometimes.
www.ducati-owners-group.com
galaxy is offline
post #9 of 18 (permalink) Old Sep 8th, 2011, 11:29 am
Ducati.MS sponsor
moto's Avatar
Images: 30
When going to SBK forks on a early 900SS, you have to consider axle size, speedo pick-up, clip-ons, fender mounts and brake mounts-- in addition to the triples for the larger SBK fork tubes.
We've done quite a few fork conversions on Supersports and Monsters. If you get the right forks, you can save a lot of money and minimize the amount of extra parts that you have to get later.
Showa SBK forks are also an option and much less expensive than Ohlins SBK forks. But consider the age and condition of anyforks you buy as many are in need of rebuilding or at least freshening up.
-M
www.motowheels.com
05 999R
01 996R
98 900SS FE
96 M944 (sold)
07 1098
06 SC1000
10 Streetfighter
10 M696
02 MV Agusta F4
02 ST4S
12 1199S
06 Paul Smart
15 Scrambler FT
moto is offline
post #10 of 18 (permalink) Old Sep 8th, 2011, 11:33 am
ThrottleJock's Avatar
If you can live without the external visuals of a Ohlins fork, you can have better-than-OEM-Ohlins performance with your stock fork if you have it rebuilt with Ohlins internals. Rick at Cogent Dynamics (NC Rick on here) can modify the internals and custom valve a 20mil Ohilins comp/rebound kit w/ springs on the old 900SS forks, or you can go balls out and have him install a 25mil cartdridge kits (again, adapted for use in 900SS fork). Probably spend about the same money on the 25mil retrofit as you would on a complete Ohlins fork, but then you know it's freshly rebuilt and valved and sprung precisely for your weight. That was my logic.
'94 900SS/CR 944
'07 Gas Gas 300 Raga
'80 Yamaha SR500 brat/bobber thing
ThrottleJock is offline
Human Verification
996 forks on a 900SS? MitchB Supersport 21 Jan 7th, 2010 1:57 pm
Ohlin oil service front forks Turboflyer Superbikes 8 Dec 30th, 2009 7:11 pm
Ohlin's Forks Upgrade dmartland Sport Classic 8 Nov 12th, 2009 6:23 pm
900ss forks mattlimo Supersport 10 Oct 16th, 2008 8:49 am
748 forks on a 900ss? sclock Supersport 5 Aug 19th, 2007 3:00 am
