On/Off Switch Headlight - Ducati.ms - The Ultimate Ducati Forum
post #1 of 12 (permalink) Old Mar 12th, 2011, 6:30 pm Thread Starter
Images: 36
I finding it to easy to hook up a switch to turn off my front headlight so not to put a drain on the battery when starting the bike?
Anyone have any help on this Thank You!
I went from the headlight bulb connector and the fuel pump sounded like it went off? I'd pull my hair out if I had some to pull............
SportBikeTrackTime
1999 Ducati 900SSie
John Deere 42"
Tora 22" sp
enjoy life ride a duc today.
curveman99 is offline
post #2 of 12 (permalink) Old Mar 12th, 2011, 7:46 pm
I don't know about f.i. supersports, but for carbed models, I know that a stock european market switch will give that capability. They seem to come up on ebay regularly.
Good Luck, John
John Horsey is offline
post #3 of 12 (permalink) Old Mar 12th, 2011, 10:25 pm
hawkgt's Avatar
I have wired a rocker switch into my 99 SSie so that I could turn off my HIDs on a cold start and of course to help the battery along.Wired it in series into the left switch cluster before the connector.That way you aren't hacking into the main harness,just the cluster harness.I believe it was pin F in the cluster plug and the green wire.I would have to open up my connection to confirm.
hawkgt is offline
post #4 of 12 (permalink) Old Mar 13th, 2011, 7:14 am
I have a 800 ss from 2004 that comes without the on-off switch and I could fit the earlier models switch that have this option. Only plug and play.
Regards
macmanaman is offline
post #5 of 12 (permalink) Old Mar 13th, 2011, 7:45 pm Thread Starter
Images: 36
Thanks I'll look into that don't know why you can't go direct to the bulb connector.(cut power to bulb)
SportBikeTrackTime
1999 Ducati 900SSie
John Deere 42"
Tora 22" sp
post #6 of 12 (permalink) Old Mar 14th, 2011, 10:24 pm
hawkgt's Avatar
Just remember that you'll have to cut into the negative or you will only switch of one beam.
Bill
1999 900SSie
1988 Honda NT650GT
hawkgt is offline
post #7 of 12 (permalink) Old Mar 15th, 2011, 1:11 am
Punch's Avatar
Off using a relay
This circuit "detects" if the engine is cranking. If it is cranking, the relay opens and cuts power to he headlight.
You can connect this just after the headlight fuse under the tank.
An alternative is to cut the negative wire to the bulb and place the relay up front somewhere. It is however convention to switch most electrical things in the positive cable/wire.
Richard Collins - 2001 900SSie
Punch is offline
post #8 of 12 (permalink) Old Mar 15th, 2011, 3:24 am
Punch - That's a solid plan there, using the solenoid/starter voltage to energize the relay disconnecting the headlight until you let off of the starter button. Simple and great. Thanks for sharing that now obviously great idea. (heads to auto store for relay and socket...)
bananaboat is offline
post #9 of 12 (permalink) Old Mar 15th, 2011, 3:35 am
Punch's Avatar
Don't worry about a socket for the relay.
All you need is two insulated spade connectors for terminals 30 and 87.
Two barrel connectors to extend the cut fused cable to the above connectors for the relay.
Two bits of cable to extend to the relay.
Cable to go from the solenoid pos to relay terminal 86.
Ring terminal and insulated spade terminal for above cable.
Cable to go from relay terminal 85 to the battery plus ring and spade terminal.
Shame you are not in Oz, I have shitloads of this stuff kicking around my shed.
Richard
Punch is offline
post #10 of 12 (permalink) Old Mar 15th, 2011, 4:51 pm Thread Starter
Images: 36
Punch
You the man and a Big Thanks!! What I did was put a switch on the low beam side going to the bulb and it works fine and for the High beam when low is in Off Pos stills give you the High Beam.
SportBikeTrackTime
1999 Ducati 900SSie
John Deere 42"
Tora 22" sp
Human Verification
Euro switch for headlight on-off MDMason HyperMotard 8 Aug 1st, 2011 1:38 am
European Headlight switch jssport Sport Touring 25 Oct 13th, 2010 10:50 am
93 900ss Headlight Switch Jhallm5 Supersport 1 Sep 11th, 2008 1:25 pm
ST3, faulty headlight switch EJP711 Sport Touring 2 Apr 27th, 2007 11:56 pm
