light reflecting back in 749/999 is this right? - Ducati.ms - The Ultimate Ducati Forum
Old Aug 24th, 2006, 3:11 pm   #1 (permalink)
Lifetime Premium
rustysrustyduc's Avatar
Hi All,
I got my 749 Dark running.. finally.. I've been working on it for 5 months and I finally got it registered and running. Great!
Now on my first night ride, I got a little surprise. You see, when I replaced my headlight housing, I decided to change things around, and I put my low beam on the bottom, and my high beam on the top. Why Not? The euro models are that way, right?
Well, the first time I hit my high-beams I practically blinded myself because so much light reflects back in the fairing.
Does it do that with the low-beams too? I know the low-beams have a cutoff pattern that would take out a lot of light on the upper part of the light, so *perhaps* it may not reflect that much light. But I don't want to pull apart the whole headlight assembly to find out and be wrong. I suspect it would still have a lot of light there.
Any ideas? Thoughts?
Thanks.
_______________________________________________
I'd like to you to meet my EVIL TWIN. Welcome to the DARK side.
rustysrustyduc is offline   Reply With Quote
Old Aug 24th, 2006, 3:39 pm   #2 (permalink)
The stock setup does the same thing, ableit more annoying than blinding
-MATT
'05 749R #233
Old Aug 24th, 2006, 3:40 pm   #3 (permalink)
mad
mad's Avatar
Yes. Just been too lazy to seal it up a little.
'08 ZX14 and '02 ZRX1200R
...previous Ducatis now sold... '05 999 and '02 ST4S
mad is offline   Reply With Quote
Old Aug 24th, 2006, 5:44 pm   #4 (permalink)
Humble
Chuckracer's Avatar
Images: 2
My '04 dosen't.
Old Aug 24th, 2006, 5:48 pm   #5 (permalink)
BHakaLaw's Avatar
My 2004 749 is not that bad with light reflecting back to the rider. When I got my 2005 999 S, I was surprised at the amount of light that comes back into the cockpit. No, its not out of the ordinary. Now I really don't even notice it though, and I suspect that you won't either the longer you ride your bike.
If I were you, I would not go tearing things apart, because I don't think it will make that big of a difference, unless you are doing some custom fab to block off all light coming back towards you. Best of luck!
RIP 2005 - 999 "S" (Termi sys., 520 conv. & Carbon Fiber Stuff)
2004 - 749 (sold 8/26/06)
"Without no struggle, you get no progress!"
www.ducati-owners-group.com
www.theocdc.com
BHakaLaw is offline   Reply With Quote
Old Aug 24th, 2006, 6:01 pm   #6 (permalink)
Humble
Chuckracer's Avatar
Images: 2
Originally Posted by BHakaLaw
...unless you are doing some custom fab to block off all light coming back towards you. Best of luck!
...which would simply be a matter of some self-adhesive foam weather stripping around the headlight cut-outs in the fairing.
I had this issue when I put the RC31 fairing kit on my Hawk. A little weather stripping solved it.
Old Aug 24th, 2006, 7:15 pm   #7 (permalink)
kaos's Avatar
i find the aftermarket screens make the light worse as they higher around the guage cluster
giallo 949- impractical,irrational,irresistible ,09 gasgas raga,11-12 gasgas cervantes 250- all in all ,my version of garage nirvana
kaos is offline   Reply With Quote
Old Aug 24th, 2006, 8:26 pm   #8 (permalink)
04749s's Avatar
I did the same thing( swapped hi and low beam ) on my 04 when i installed the mag bucket and stays ..
but i haven't noticed any more light .
04749s is offline   Reply With Quote
Old Aug 25th, 2006, 3:28 am   #9 (permalink)
level7's Avatar
That wouldn't be such a bad thing as people can see you better all lit up at night. Just as long as your forward vision isn't impaired...which it sounds like it is.
998 Monoposto - The final form of a legend
"Each day is a gift, have fun" - 11 year old boy who died of cancer
level7 is offline   Reply With Quote
Old Aug 28th, 2006, 8:13 pm   #10 (permalink)
Lifetime Premium
Oh.. OK, this is what I wanted to hear. I guess the next time I'm in there I'll think about putting some weatherstripping in there. But I'll have to see how hot the housing gets.
Thanks guys!
Do You Wear A Back Protector Riding Your ST? BlueST2 Sport Touring 15 Nov 5th, 2006 5:53 pm
To Aspen and back I rode... RocketJohn Ride Tales 4 Jul 31st, 2006 8:43 pm
Neutral Light on while in gear Leonard Ducati Motorcycle Chat 5 Jun 27th, 2006 9:36 am
Wind sheild light on 05-06 749/999 montducati Superbikes 7 Jan 16th, 2006 8:35 am
