Fuel Pump O Ring grr! - Ducati.ms - The Ultimate Ducati Forum
post #1 of 21 (permalink) Old Jul 8th, 2010, 7:13 pm Thread Starter
Images: 2
Bike just came back from paint, and the painter removed the fuel pump assembly. I'm going by the manual, and it says there should be an O ring in the housing, right where it fits with the tank. There isn't. I've emailed him but I'm guessing it's gone missing.
If that's the case, can I use liquid gasket stuff on it? It DOES appear there was some yellowish transparent gunk at the tank-pump meeting location, so maybe Ducati switched to a liquid/rubbery stuff?
I really don't want to have to wait weeks and weeks to ride my bike...blah.
Thanks guys!
2008 1098s mods (IIRC): Dymag CF Rims, Braketech ceramic CMCs, Discaccati rear rotor/caliper, RAM magnesium swingarm, magnesium full 30mm offset triples, FGRT803s, TTX, EVR slipper+slave, magnesium clutch side cover, STM Ti thong, Brembo RCS levers (both sides), Speedymoto EVO waterpump, Corse silicone rad lines, Ti front axle+clutch bolts+caliper bolts, all bodywork CarbonDry carbon fiber, Leo Vince Ti full, Nemesis, Rizoma barends, rearsets, Oberon signals, Evoluzione eliminator, some other shit I don't know the names for.
shawngibson is offline
post #2 of 21 (permalink) Old Jul 8th, 2010, 7:26 pm
kaos's Avatar
proper o-ring is a must.every ducati dealer should have the part in stock as its a common service item.search here for cross over o-rings but do so knowing it must be an exact match or gas could start leaking over a hot motor at the worst of times
giallo 949- impractical,irrational,irresistible ,13 txt pro 280,2015 beta 300rr race all in all ,my version of garage nirvana
kaos is offline
post #3 of 21 (permalink) Old Jul 8th, 2010, 7:35 pm
mbevans's Avatar
Gotta use the O-ring! Or you will leak! Most purchase new ones from the dealer. I have used white-grease on the O-ring/sealing surface, TAKEN my time, as it is super tight fit for sure, start one side and push carefully............
2003 Ducati ST4S (Yellow, the faster color)
2014 Beta 450RS (Latest Italian dirty girl)
2008 Aprilia RXV550 (Sold the Beast)
2006 Ducati 999s (Sold)
2001 Ducati 996 SPS (Crashed)
2001 Ducati 748-890 (Sold)
1997 Ducati 748 (Sold)
1993 Ducati 888SPO (Crashed)
Too much Jap or British crap to mention!
mbevans is offline
post #4 of 21 (permalink) Old Jul 8th, 2010, 7:36 pm Thread Starter
Images: 2
Crappy. Thanks guys, I'll call dealer in the morning. Fingers crossed they have one in stock...
post #5 of 21 (permalink) Old Jul 8th, 2010, 7:49 pm
duc995's Avatar
Try desmotimes.com ... I got one in just a few days!
-Rob
'12 Kawasaki ZX6r trackday weapon
'97 Ducati 916 - retired
duc995 is offline
post #6 of 21 (permalink) Old Jul 8th, 2010, 11:42 pm
BrianG's Avatar
Grease up the o-ring and the tank-lip real good, and try to keep it square as you press it home.
Some say to use the mounting bolts to pull it in, turning each bolt one turn at a time, but I could never get the mounting bolts to bite before the assembly slipped in with the grease.
2005 999S
I try to take one day at a time, but sometimes several days attack me at once.
BrianG is offline
post #7 of 21 (permalink) Old Jul 9th, 2010, 12:17 am
The Road Beckons...
WakeDude's Avatar
If no other place, contact DucatiDepo.com, they are the Ducati "Chop-Shop" but usually have most of those awkward parts on hand.
-Alex
-Alex
2008 Hypermotard 1100 S "Lola" - (SOLD)
2006 Multistrada 1000S DS "Duckie" - (SOLD)
Mexico TripDescubre-La-Vida Blog
WakeDude is offline
post #8 of 21 (permalink) Old Jul 9th, 2010, 2:47 am
Yep you need an O-Ring and lube both the O-ring and the mating surface of the tank. I have always had good luck using a few longer bolts in the threads and gently eased them in little by little. If you are careful it will drop right in - be careful though because it is really easy to pinch, or cut the O-ring, and then you'll have leaks and have to go buy another one. Don't ask me how I know
Good Luck!
DFresh1 is offline
post #9 of 21 (permalink) Old Jul 9th, 2010, 2:51 am
Directorate of Internal Security
amullo's Avatar
Images: 313
Good Luck!
Thats how i do it..
Longer bolts then the mounting ones and then one turn per bolt until its in, then replace one bolt at a time. I use petroleum jelly instead of grease, but it should work either way.
//amullo
2010 Multistrada 1200s - engine mapped by tomtom, Íhlins mechatronics SCU
amullo is offline
post #10 of 21 (permalink) Old Jul 9th, 2010, 6:34 am
masterrch's Avatar
your going to crap that o-ring for the 1098 fuel pump is like $70 dollars, the dealer should have it in stock
masterrch is offline
Human Verification
Fuel Pump/Tank O-Ring *** PITA *** SeanFromTX Superbikes 19 Oct 19th, 2014 9:40 pm
1098 fuel pump o-ring--WTF masterrch Superbikes 2 Nov 22nd, 2009 10:31 am
Fuel pump O-ring placement? TrojanHorse Superbikes 3 Mar 19th, 2009 7:40 am
O Ring on fuel pump = fuel weeping ST4 Steve1445 Sport Touring 4 Jan 28th, 2008 5:09 pm
Fuel pump o-ring 999, QD questions Dyno-sore Superbikes 0 Sep 4th, 2006 1:02 pm
