I am making up a billet caliper mount for a brembo P2.24 rear caliper (64mm mounting centres) and was wondering if anyone has a drawing showing the pad swept area and mounting bolt hole dimensions?
From my measurements the offset between the centre of the piston and the centre of the mounting holes is either 15-16mm. Can anyone confirm if this is right?
