Hi Just wondering if anyone has the low down on coolants??
Is it possible to mix coolants from the same manufacturer without having any adverse side affects??
For example is it ok to mix Motulcool with Motul Mo Cool & motul inugel plus coolant. Have all sorts of stories about coolant & the more you read the more confusing it gets.
I am in a cooling system related business and will give you the same advice I give my customers. Don't mix coolants it's not worth it.
Some mix ok, some can become an acidic mix and attack the inside of the radiator.
I have seen new radiators destroyed in 2 years by incompatible coolants being mixed together and they were copper ones not the more susceptible alloy ones on our bikes.
Drain the old coolant out, refill with distilled water, run for an hour or so to flush it, drop it out and in with the new coolant.
Too easy.
I just switched out to Engine Ice. I wasn't sure about the grandiose claims of this insane drop in temps, but I'll tell you what my "highway" temps are down at least 25 degrees, "in traffic" temp is down 10-15 degrees, and "STUCK IN TRAFFIC" temp is down about 10 degrees. To me that is a HUGE improvement, as my 749 ran insanely HOT!!
MoCool is compatible with most antifreezes, including the new long-life versions MOTUL MoCool additive is designed for aluminum, cast iron, copper, brass, and bronze systems.
Motul MoCool is a radiator additive which will reduce cooling system temperature by as much as 15*C (30*F) ( similar in function to "Water Wetter".
MOTUL MotoCool Coolant is a ready to use (no mix) coolant with a high boiling point/lower freezing point and corrosion inhibiters.
Thanks for the heads up on the coolant issue. I thought it might be ok to mix coolants of the same brand. I have been using Motul but would like to know if someone was having success with another product.
Related Threads
2.5M posts
93.7K members
Since 2005
