Jan 4th, 2010, 9:50 pm
Why is my 916 SP3 running rough?
At 180kph on the highway with a very strong headwind, the power cut out on the engine of my 1996 916 SP3. It stalled and I slowed to 100kph and tried to pop start it on the road shoulder. It wouldn’t. I waited for a minute and tried the starter. It wouldn’t start. Then I waited a few more minutes and it started up.
It was running a bit rough but ran ok at lower rpms and performed better as the rain came and temperatures cooled (it was a very hot day).
Two days later I rode it, it’s ran ok while it was somewhat cold, but as temperatures increased it started running rough again.
Any ideas as to what would cause this?
Oil change was at least 1500 kms ago.
Thanks in advance.
There's nothing more life-reaffirming than knowing you could die at any second. (",)
Jan 5th, 2010, 1:54 am
I'm thinking it's a fuel mapping issue maybe?
I already did the fuel pressure regulator.
I'l have them do the plugs, oil and maybe look at valves?
Any ideas?
Jan 5th, 2010, 4:50 am
The Finder
Pull the battery tray on the right side of the bike. Behind it, the electrical connector (going from the stator to the regulator/rectifier) is probably fried there. If they get a little corrosion, they heat up. If you unplug it and it looks burnt, try cutting out the connector entirely and hardwiring it. Otherwise you will probably have to replace the R/R.
2001 Ducati 996 R
1991 Kawasaki ZX-7R K1 homologation
2001 Ducati 996 track bike
1971 Honda CB450 cafe racer
1989 Honda NSR250 MC18/derestricted
2001 Derbi GPR 75
1998 Ducati 916 SPS #909(sold)
2000 Ducati 996 SPS #1134(sold)
1999 Laverda Formula 750S(sold)
2001 Ducati 996 Monoposto(sold)
1998 Ducati 748 (sold)
1999 Ducati Monster 900 (sold)
1995 Ducati 916 (sold)
1997 Suzuki TL1000s (sold)
1994 Honda VFR750 (sold)
1988 Yamaha FZR1000 (sold)
1990 Suzuki Katana 600 (sold)
1986 Yamaha Radian 600 (sold)
1985 Kawasaki GPz750 (sold)
1983 Suzuki GS450E (sold)
Jan 5th, 2010, 5:10 am
some damn moderator
Sounds more like a clogged fuelfilter or cloggged injector to me. How long ago did you change the fuelfilter?
It COULD maybe be a charging issue, but i woldn´t think so.. The charging issue would kill the battery and you wouldn´t be able to start it up again (probably..).
//amullo
//Anders
2010 Multistrada 1200S Sport (White)
Mapped by Hypertrick in stock ECU
Öhlins semiactive SCU
Jan 5th, 2010, 5:23 am
coil perhaps? my inference is bec of the op's statement of the heat.
 Duck fever!!!
Jan 5th, 2010, 8:47 am
The Finder
After several minutes of sitting, the battery builds up enough of a charge to fire the motor. After restarting, it's not dying because of temperature, it just takes a couple minutes for the built up battery charge to run too low.
2001 Ducati 996 R
2001 Derbi GPR 75
Jan 5th, 2010, 9:08 am
How would the battery "build up" a charge if the motor isn't running?
2008 S2R1000, The mod whore
2003 RC51, The stock one
2002 ZX-7R, The green meanie (sold)
Jan 5th, 2010, 9:50 am
The Finder
Through the non-instantaneous chemical reaction between a series of differing metal plates sandwiched in a conductive, acidic solution.
2001 Ducati 996 R
2001 Derbi GPR 75
Jan 5th, 2010, 9:49 pm
thanks guys, it sounds like an injector or fuel delivery problem to me...
Anyway, I am not sure at all.
I belive the fuel filter was changes 1500kms ago.
I'll let you all know.
Jan 5th, 2010, 10:47 pm
The Finder
It definitely could be a pinched fuel line or some other fuel issue.
But you can check out that connector by taking 1 minute to remove the right fairing and another 5 to pull the battery and tray. Only takes one wrench...
2001 Ducati 996 R
2001 Derbi GPR 75
