Originally Posted by Cigarlvr
What is the difference between the two? I know on the 999 there is some carbon on it but from what I see on the 749R it looks like suspention and a few more HP
this is from DUCATI.COM
Here is the S
CHASSIS
Frame Tubular steel trellis
Wheelbase 1420 mm / 55.9 in
Rake 23.5° - 24.5°
Front suspension
Showa 43 mm upside-down fully adjustable fork with TiN surface treatment
Front wheel travel 125 mm / 4.9 in
Front brake 2 x 320 mm semi-floating discs, 4-piston 4-pad caliper
Front wheel Y-shaped 5-spoke light alloy 3.50 x 17
Front tyre 120/70 ZR 17
Rear suspension Progressive linkage with fully adjustable
Showa monoshock
Rear wheel travel 128 mm / 5 in
Rear brake 240 mm disc, 2-piston caliper
Rear wheel Y-shaped 5-spoke light alloy 5.50 x 17
Rear tyre 180/55 ZR 17
Fuel tank capacity 15.5 L / 4.1 US gal (includes 3 L / 0.8 US gal reserve)
Weight * 186 kg / 410 lbs
Seat height 780 mm / 30.7 in
Instruments Speedometer, rev counter, high beam indicator, turn signals, oil pressure warning light, low fuel warning light, neutral light, water temperature, immobilizer system
Warranty 2 years unlimited mileage
Colour combinations:
(Tank-Frame-Wheels) (red-red-black) (black-black-black)
Versions Single or dual seat (dual seat not available in North America)
* = The weight excludes battery, lubricants and, where applicable, cooling liquid.
ENGINE
Type L-twin cylinder, 4 valves per cylinder Testastretta Desmodromic; liquid cooled
Displacement 748 cc
Bore x Stroke 90 x 58.8 mm
Compression Ratio 12.3:1
Power* 85.4 kw - 116 hp @ 10500 rpm
Torque* 8.4 kgm (60.8 lb-ft) @ 8500 rpm
Fuel injection Marelli electronic fuel injection, 54 mm throttle body
Exhaust Single steel muffler with catalytic converter
Emissions Euro2
TRANSMISSION
Gearbox 6 speed
Ratios 1st 37/15, 2nd 30/17, 3rd 28/20, 4th 26/22, 5th 24/23, 6th 23/24
Primary drive Straight cut gears; ratio 1.84
Final drive Chain; Front sprocket 14; Rear sprocket 38
Clutch Dry multiplate with hydraulic control
POWER CURVE Click here
* = Data calculated using an inertia dynamometer
here is the R
Rake 23.5° - 24.5°
Front suspension
Öhlins 43 mm upside-down fully adjustable fork with TiN surface treatment, for radial calipers
Front wheel travel 120 mm / 4.7 in
Front brake 2 x 320 mm semi-floating discs, 4-piston 4-pad radial caliper
Front wheel Y-shaped 5-spoke light alloy forged 3.50 x 17
Öhlins monoshock
Rear wheel Y-shaped 5-spoke light alloy forged 5.50 x 17
Fuel tank capacity 18.3 L / 4.8 US gal (includes 3 L / 0.8 US gal reserve)
Weight * 183.5 kg / 405 lbs
Versions Single seat
ENGINE
Displacement 749 cc
Bore x Stroke 94 x 54 mm
Compression Ratio 12.7:1
Power* 89.1 kw - 121 hp @ 10500 rpm
Torque* 8.6 kgm (62.2 lb-ft) @ 8250 rpm
Termi I belive or so the pic shows
Emissions Euro2
TRANSMISSION
Gearbox 6 speed
Primary drive Straight cut gears; ratio 2.11
Final drive Chain; Front sprocket 15; Rear sprocket 35
Clutch Dry multiplate with hydraulic control slipper clutch
close
*** if you can afford it get the R - I got a dark because I could pay cash for it. My next Duc will be a R either the 749 or 999. Depends on how much cash I have the day I get the wild hair up my bum. ***
Good luck and happy shopping .
