Sep 16th, 2009, 8:51 pm
848 parts on a 748?
Looking at a 748, planning on some heavy modification. Lots of anodizing, CF, etc. My main questions are:
1. Can I use 848 forks in a 748 triple, or do I need a modified triple? I want the radial brakes
2. Can I use stock 848 rims on a 748? Obviously if I'm switching out the front end, the front wheel will be fine and March's website says that their rear rims for 748s and 848s are the same measurement.
3. How would you propose putting a 848 tail on a 748? I was told the subframes will not interchange and am worried about rigging the tail to the 748 subframe. Hopefully this last idea is not too blasphemous for the diehards.
Of course I considering just jumping for the 848, especially because by the time all is said and done, I plan to spend the same amount on a 748. But I figured I would rather have a really custom 748 than a stock, dime a dozen 848. Thoughts and suggestions greatly appreciated.
Sep 16th, 2009, 9:28 pm
I take it you are a new to Ducati?
Why are you picking the 748 as a starting point? if its a cost issue I think you are setting yourself up for failure on your 848/ 748 hybrid.
Its not a fact that 748s are more prone to flaky rockers, it should be tho.
Instead of a "dime a dozen" 848 with better maintenance intervals, more power, and an improved chassis you'll have a ""dime a dozen" 748 with unremarkable suspension, and no speedometer.
There are options to get radial brakes without having to do a front end swap. I could even CAD up some fork bottoms if you arent in a rush, it will be less than the front end swap. Not cheap tho
Sounds uninspired IMHO.
Oscar
I need a bigger living room
Sep 16th, 2009, 10:06 pm
Sounds like a massive undertaking. If money is no object, why start with the 748?
Sep 16th, 2009, 10:39 pm
Banned
+1 I'm confused myself...
Explain a bit more about what you wanna do.
Sep 16th, 2009, 11:59 pm
stock front brake in ducati 848 2010 is radial or not.i fell it not radial brake.
Sep 17th, 2009, 3:16 pm
I picked the 748 because I don't want a liter bike. That leaves 748 749 and 848. I don't want a 749 for the same reasons that it lasted all of......3 years? The headlights are ugly and it's not equiped with a single sided swingarm. I want a bike that looks all my own and I won't hesitate to tear apart and modify. For the price of just the 848, I can buy a 748 and everything else to go with it, and the 748 already comes with a dry clutch. Plus I wouldn't be as inclined to tinker with an 848. Even if I did get an 848, then why not just get a 1098?
Mostly I'm just curious about wheel fitament as it seems like it would be a lot more hassle and money for the radials with little benefit. Anyone know if stock 848 rims will work on a 748?
Sep 17th, 2009, 3:21 pm
Originally Posted by Cardi
I want a bike that looks all my own and I won't hesitate to tear apart and modify. [/B]
AMEN BRUTHA!!!!!
my last big "project"
GOTTA MAKE IT YOUR OWN!
Sep 18th, 2009, 10:07 am
All the pairs I'm finding on Ebay are radial: http://cgi.ebay.com/ebaymotors/Ducat...=p4506.c0.m245
Word.
Sep 18th, 2009, 10:21 am
Ducati.MS sponsor
1. If you use the 848 forks, you will need a 848 front axle and 15mm offset rotors.
2. You can then use the 848 wheels and 848 rotors on the front. Rear is a direct bolt on.
3. 848 Tail will require subframe mods.
=M
Sep 18th, 2009, 1:50 pm
AMEN BRUTHA!!!!!
What is this? It's gorgeous...
2008 1098s mods (IIRC): Dymag CF Rims, Braketech ceramic CMCs, Discaccati rear rotor/caliper, RAM magnesium swingarm, magnesium full 30mm offset triples, FGRT803s, TTX, EVR slipper+slave, magnesium clutch side cover, STM Ti thong, Brembo RCS levers (both sides), Speedymoto EVO waterpump, Corse silicone rad lines, Ti front axle+clutch bolts+caliper bolts, all bodywork CarbonDry carbon fiber, Leo Vince Ti full, Nemesis, Rizoma barends, rearsets, Oberon signals, Evoluzione eliminator, some other shit I don't know the names for.
