1098 throttle sync question - Ducati.ms - The Ultimate Ducati Forum
post #1 of 1 (permalink) Old Aug 15th, 2009, 10:08 am Thread Starter
masterrch's Avatar
My '07 1098 w/full termis started running really rough on acceleration,so I got the old mercury sticks out and had a look at what was going on,well the readings were way off so I shut the bike off and scewed in the by-pass screws and rechecked the readings still way off so I adjusted the balance screw clockwise till both cylinders were the same almost a full turn,then I backed out the bypass screws 3/4 a turn like the manual says and the bike no longer runs rough and is much smoother at steady throttle than before.
I know my CO it not set at an optimum without a meter but my real question is should I have the TPS reset?
I have been on the fence about buying one of the FBF VDSDS things.
Rich
masterrch is offline
Human Verification
Exhaust Question for California 1098 Owners Nomore76 Superbikes 3 May 19th, 2009 1:45 pm
Question about throttle cable adjustment screws dkeyser48 Supersport 0 May 8th, 2009 10:44 am
1098 tricolore catalytic converter question? parabellum Superbikes 6 Oct 5th, 2008 10:56 pm
900 SS throttle sync question 4U2NV Supersport 7 Aug 8th, 2007 4:24 am
