Depends on what you want to do here..
BETTER performance
* 14T front sprocket = lower gearing = increased acceleration
* lightweight wheels = less unsprung/rotating mass = better acceleration, brakes and definatly faster cornering
More horsepower
Stage1
*larger airrunners
*Re-timed cams (advance inlet cams and set exhaust cams)
*Powercommander 3 USB/reflashed ECU and custommap by a good dyno tuner
Stage2
*"Euro" S or 996R cams
*Larger exhaust
*Remapped ECU or PC3
Stage3
*TIT rods
*Larger valves
*high compression pistons
I´d go with lighter wheels and a 14T front sprocket, since those give the best "bang for the buck" Then a PC3 or a re-flashed ECU.
//amullo
//Anders
2010 Multistrada 1200S Sport (White)
Mapped by Hypertrick in stock ECU
Öhlins semiactive SCU
