Ducati 996 or 998 or 916 Engine - Ducati.ms - The Ultimate Ducati Forum
post #1 of 32 (permalink) Old Mar 15th, 2017, 8:44 pm Thread Starter
ammoduc's Avatar
I have an engine case with upper. How can I tell what size cc engine it is? I measured the piston diameter and it was 996 or 998. Can I tell just by looking at the stampings or the ser# ???
2000 MV AGUSTA F4- Ride
ammoduc is offline
post #2 of 32 (permalink) Old Mar 15th, 2017, 8:47 pm
Namor's Avatar
Piston on 996 is 98mm. The 998 is 100mm.
What do you mean by "upper?"
Just post a couple of pictures of what you have.
97 916/996 "The Time Machine"
Namor is online now
post #3 of 32 (permalink) Old Mar 15th, 2017, 8:59 pm Thread Starter
ammoduc's Avatar
Thanks for the reply, I will post some pics tomorrow. Kinda leaning towards the 996 but we will see.
ammoduc is offline
post #4 of 32 (permalink) Old Mar 16th, 2017, 9:52 am
Danbuc's Avatar
You are comparing two completely different engine designs here. You can rule out one easy just by looking at the cylinders and heads. Are they desmoquattro or testastretta cylinders/heads?
If they are testastretta then it's a 998 or newer. If they are desmoquattro cylinders/heads then it is a 996 or older. Either way, based on that bore size and piston stroke should tell you what you need regarding engine displacement.
2010 Triumph Thruxton
2000 748 cafe'esque streetfighter
2001 748R
2003 Monster- let's call it a future coffee table.
Danbuc is offline
post #5 of 32 (permalink) Old Mar 16th, 2017, 10:34 am
If you are trying to identify a complete engine, why not look at the engine serial number?
It almost sounds stupid, I know.
On my 2002 900SSie engine I can see that it is 904 cc, 2 valve per cylinder air cooled (ZDM904A2XXXX).
900SSie 2002 - Senna
SalkinSalkin is offline
post #6 of 32 (permalink) Old Mar 16th, 2017, 2:58 pm Thread Starter
ammoduc's Avatar
Thank you for the reply fellas. Here are some pics, feel free to ask me any questions.
ID:	799449   Click image for larger version
ID:	799457   Click image for larger version
ammoduc is offline
post #7 of 32 (permalink) Old Mar 16th, 2017, 3:07 pm
Danbuc's Avatar
Well it's certainly not a 998 lol. Case finish looks like sandcasting hmmm. Intriguing. Bore looks like 748 though. 88mm is small.
2001 748R
Danbuc is offline
post #8 of 32 (permalink) Old Mar 16th, 2017, 4:14 pm
DukeDesmo's Avatar
Images: 196
996 is 98mm bore, 916 is 94mm, 748 is 88mm and those look like Desmoquattro heads. So a 748 of some description.
916, M900 & Guzzi LeMans II
DukeDesmo is offline
post #9 of 32 (permalink) Old Mar 16th, 2017, 4:30 pm
SS904's Avatar
On bikes shipped to the US, the number stamped on the engine starting with SB5 means it is a 996. SB8 is 916, SB3 would be a 748. I have found some info that indicates SB5 may also mean 998 or even 999, but I am not 100% sure of that. In any case, those are DQ heads, so it is a 996.
The X after the SB5 means it is a 1999 model year.
The 88MM bore on the cylinder you show must be from a 748. Does it fit the cases you have? My understanding is the 996 had a larger stud spacing than the old 916 and 748 cases. Something is odd if that cylinder fits a case with an SB5 number on the ID. Unless, and i have not heard of this before, the 748 inherited the same 996 stud spacing when they replaced the 916.
Dan.
2003 ST4s (The Truck)
1995 916 (Junk Yard Dog)
SS904 is online now
post #10 of 32 (permalink) Old Mar 16th, 2017, 9:03 pm Thread Starter
ammoduc's Avatar
YES Both upper cylinders fit perfectly. It could also be that its not all original in the sense that someone might of put it together..At the end of the day they all fit. I'm thinking of selling it but didn't know much about it. I have a 748 Frame that I might see if it fits.
ammoduc is offline
Human Verification
Magnecor Ignition Cable Set: 748 / 916 / 996 / 851 / 888 / 996R / 998 moto Motowheels 2 Mar 2nd, 2017 10:39 am
Corse Dynamics Aluminum Coolant Tank V2: 748 / 916 / 996 / 998 moto Vendor Specials and Group buys 0 Jun 4th, 2016 8:31 pm
Corse Dynamics Aluminum Coolant Tank V2: 748 / 916 / 996 / 998 moto Vendor Specials and Group buys 0 Jan 3rd, 2016 9:03 pm
Corse Dynamics Aluminum Coolant Tank V2: 748 / 916 / 996 / 998 moto Vendor Specials and Group buys 0 Dec 20th, 2015 11:35 pm
