Desmo Stick Coils - Ducati.ms - The Ultimate Ducati Forum
post #1 of 28 (permalink) Old Feb 15th, 2017, 9:24 pm Thread Starter
Namor's Avatar
Desmo Stick Coils
This thread is a final summary of Serious Black's original thread Stick Coil Conversion. Stick coil conversion - because I was curious. Inspiration goes to him. (Picture 5 is stock)
Stick coils, or "coil overs" on the old Desmos 748, 916, and 996 is what this thread is about. Effectively you remove the lunch box coil packs and wires and replace them with coils that fit in the spark plug galleys/passages.
The coils being used are 2008 Kawasaki ZX600/636. Part number F6T560. They fit very well. It is worth a few dollars to purchase the ZX harness for the correct pick-ups/connectors to the new coils. (Picture 1)
To make these coils work your spark plugs must allow you to remove the caps on the ends of the spark plugs. (Picture 2) New plugs are in order of if you cannot remove the end caps. I suggest iridium or platinum replacements b/c copper plugs don't hold up well to coil overs.
(Picture 3) Coils, all rubber is removable. -- Insert joke here -- In the picture, one of the coils has a rubber collar off and "feels" to seat better without it, but the collar will prevent debris from falling into the plug passage. Ultimately, it makes no difference and the inclusion or exclusion of the collar depends on how anal retentive a person is.
Wiring - The Ducati brown wires (x2) one per coil go to the red on the Kawaki harness. Those go to the Kawaki RedSee picture 2 if you are confused. The Ducati Green (x1) and Grey/Yellow (x1), different wire per coil, are the remaining wires that you need to solder to the Kawaki White/Green, Blue/White or whatever White/Color combination you took from the Kawasaki.
Picture 4 - Horizontal installed, no issue with v-cowl clearance
ID:	791666   Click image for larger version
ID:	791674   Click image for larger version
ID:	791682   Click image for larger version
ID:	791690   Click image for larger version
97 916/996 "The Time Machine"
Namor is online now
post #2 of 28 (permalink) Old Feb 15th, 2017, 9:29 pm Thread Starter
Namor's Avatar
Picture 1 - Vertical installed, clears the wires and fuel pump housing
Picture 2 - Airbox on. Get over it, it is a test item. It has no bottom and is held together by fiber glass b/c it is one of those old flimsy sort that cracks on it's own. If I install a normal box rpms jump 2k. Indication of air restriction. Zero conclusion on this.
Picture 3 - Gutted breather with line to reed valve seen in picture 2. No conclusion on the significance of this other than I saved weight by deleting the crank case breather black thing and I did it b/c I was told OEM is best.
Now, to the results of doing the coil overs. "..... ... ... ." After simultaneously installing a new set of gears and chain I cannot say much. I can say that with a more than partially ruined Shoria battery (I keep it in to complete the circuit and typically jump start at the track) The Time Machine starts easier. Not much, but enough to notice and no need to jump. But just barely. No normal person could start it.
Running, I like to think that it is smoother. Is it me or the new gears/chain? Mostly the later. In my scientific approach to everything, I doubled the spark plug gap with my eye ball and some alcohol. I did compare the spark with the coil overs and bigger gap and the spark was/is substantially larger than OEM gap and coils.
I like the mod b/c it cleans things up and reduces weight. I speak of no performance gains at this point. And I will follow up on this thread if the coils ruin my ECU and/or as I put more miles on it.
ID:	791698   Click image for larger version
ID:	791706   Click image for larger version
Namor is online now
post #3 of 28 (permalink) Old Feb 16th, 2017, 2:20 am
A big thankyou for the write up, been contemplating doing this for a while now.
Grumbly is offline
post #4 of 28 (permalink) Old Feb 16th, 2017, 2:29 am
spinoli1's Avatar
Very informative post. I'm watching with interest, good luck.
HM1100S, 998Bip
spinoli1 is offline
post #5 of 28 (permalink) Old Feb 16th, 2017, 9:42 am
Thanks for the info
weird question, but do they fit 1X98 head?
zambony is offline
post #6 of 28 (permalink) Old Feb 16th, 2017, 3:14 pm Thread Starter
Namor's Avatar
Originally Posted by zambony View Post
... but do they fit 1X98 head?
I bet they will function fine, but the length of the coil may be the issue. I can take a measurement of the Kawasaki coil if someone has a XX98 coil measurement for me to compare.
Namor is online now
post #7 of 28 (permalink) Old Feb 16th, 2017, 3:25 pm
miolta's Avatar
Funny that they used those "lunch boxes" in top level WSBK bikes
Name:	Ducati 1098 R Checa 2011 07.jpg
ID:	791873   Click image for larger version
Name:	WSBK2011 PIT7D.JPG
miolta is offline
post #8 of 28 (permalink) Old Feb 16th, 2017, 5:32 pm
SS904's Avatar
True enough. Top level race bikes used to use carbs too.
Neat idea. Not sure it's something I'm going to run out and do right away. I have enough things I actually need to do first!
I'm more interested in your air box situation... Are you actually running no filters with the bottom cut out? I assume this is a race bike, so maybe not subject to the typical crap a road bike might see, but...
Dan.
2003 ST4s (The Truck)
1995 916 (Junk Yard Dog)
SS904 is online now
post #9 of 28 (permalink) Old Feb 16th, 2017, 5:37 pm Thread Starter
Namor's Avatar
Odd, given that everything after 02 came with the coil overs. I would like to know the reason they did that on that race bike.
Filters in the air runners. It was/is a track bike. But since I am in school and tracking is not a "reasonable" expense right now, I put a brake light back on (no horn, headlight, ect.) and commute some b/c a bike should not just sit.
And, the coil and airbox experiments are to facilitate an easier engine swap. Something like an 848 stroked to 916 or 984. That, b/c the engine is lighter and better.
Namor is online now
post #10 of 28 (permalink) Old Feb 17th, 2017, 6:08 am
I have a set of 1098 at home I'll measure them tonight. Thanks!
Where did you bought the Kawa coils, and how much did you get them for?
zambony is offline
Human Verification
No one is able to reset my Desmo Service Xanthos Multistrada 1 Feb 16th, 2017 5:42 pm
750 desmo head vs non desmo Scrannel Vintage 1 Jan 23rd, 2017 12:54 pm
New Desmo Times Axle Plates for ST4/3 & Post 2001 M750/M800/M900/M1000 macraige Parts and Accessories 7 Oct 17th, 2016 11:36 am
Painful Desmo Service OAD Multistrada 43 Jul 12th, 2016 5:36 pm
500cc Sport Desmo -rear brake torque specs needed Dnaj11 Vintage 6 Jan 16th, 2016 4:48 pm
