996S or 998 - Ducati.ms - The Ultimate Ducati Forum
post #1 of 35 (permalink) Old Feb 15th, 2017, 3:40 pm Thread Starter
996S or 998
Hey all,
I am looking to get into the 9XX series of bikes. I found a 2002 998 mono for ~$5200 and a 2001 996S mono for $7200. They have ~7k and ~9k miles respectively. I know the 998 has the better engine, but as for collector value, the 996S might have an edge. Right now I am leaning towards the 998 because they're pretty rare and easier to work with. Any thoughts/recommendations?
Thanks
998
996S
Dieselboy is offline
post #2 of 35 (permalink) Old Feb 15th, 2017, 3:44 pm
PhilBoncer's Avatar
Are you planning to ride it much? If yes, the 998 has the edge. If no, it's more for a collection, then the 996S has the edge. Me, I'd get the 998 and put 100K on it, and screw the collectors value. YMMV.
PhilB
trussdude and ProphetPVD like this.
1993 Ducati Monster M900, 257K miles (so far)
PhilBoncer is offline
post #3 of 35 (permalink) Old Feb 15th, 2017, 3:51 pm Thread Starter
It will definitely be ridden, but I have 2 other bikes so each will probably make ~1500 miles a year.
post #4 of 35 (permalink) Old Feb 15th, 2017, 4:51 pm
ProphetPVD's Avatar
Two words... flaking rockers. They are a concern in the Desmoquattro engines, in the Testastretta they're not. Other than that, it's purely a matter of whether or not you prefer the slab sided '02 fairings or the earlier vented ones. Personally, I don't feel that a 996s is all that collectible anyway, it's not like it's an SPS or a Varese built 916... I'd go with the 998.
ProphetPVD
'02 748R, #0954
ProphetPVD is offline
post #5 of 35 (permalink) Old Feb 15th, 2017, 5:08 pm
sburns2421's Avatar
Testaretta engine is a clear improvement over the desmoquattro. If they were the same price I would say 998. Given that the asking price is much cheaper, assuming no surprises in condition I would say it is a no-brainer.
Buy the 998 and get a set of Ohlins forks for it for the same money as the 996S.
sburns2421 is offline
post #6 of 35 (permalink) Old Feb 15th, 2017, 5:40 pm Thread Starter
Price on the S seems high to me, I've seen better examples in the 6-6.5k range. I spoke with the 998 owner and he said he just had the fuel pump replaced, but other than that it's mint, and at 5k it's a steal IMO.
Zixxer2Go likes this.
post #7 of 35 (permalink) Old Feb 15th, 2017, 5:51 pm
ray916mn's Avatar
Not quite enough information to make a pick. All things being equal, the 998 does seem like the better choice, however given the age and mileage on both bikes maintenance has significant value.
Both bikes are at the age and mileage where if they have not had a valve and belt service or new tires within the past 5 years they should probably be serviced. Their mileage indicates that have sat quite a bit too, so looking inside the gas tanks and making sure they are clean and rust free is important too. The value of a valve and belt service, new tires and replacing an internally rusted gas tank can easily be in the $1500-2000 range. Given the costs of service and maintenance on Ducatis it is important to consider where bikes are in their service schedule when determining the value of a bike as well as their condition.
ray916mn is offline
post #8 of 35 (permalink) Old Feb 15th, 2017, 5:53 pm
kdehkordi's Avatar
998 all day, everyday.
With such low mileage and age, I would figure on another 1-2k for "surprises"; electrical gremlins, leaking forks, shock needing a rebuild etc... Ruber O-rings dry with age, not mileage. Even if they're not leaking now, after a couple thousand miles I would give the bike another once-over.
fyi; I would rather buy one that's ridden regularly with no more than 30k mileage wise.
When in doubt, lean more...
02 SS750 Lovely first bike Red (sold)
02 St4s Rip 11/18/11 -- running now Matte Grey (sold)
03 St4s Restored from salvage Senna (sold)
10 Multi S 3yr and 55k mi Black
12 RSV4 F 15k mi
kdehkordi is offline
post #9 of 35 (permalink) Old Feb 15th, 2017, 6:18 pm
ray916mn's Avatar
I forget to mention, I'm also not as enthused about the modifications to the 998 while the 996S looks very original and correct.
The 998 lacks mirrors, turn signals and may have a hack job rear fender eliminator. Is the CF airbox a real CF airbox or just CF airbox trim panels? V&H cans, meh. If it were my bike, I'd be compelled to fix it with proper parts and eliminate any faux parts.
All things being equal an unmolested Ducati is always nicer in my book than a tarted Ducati.
ray916mn is offline
post #10 of 35 (permalink) Old Feb 15th, 2017, 6:19 pm Thread Starter
996s I think has a better service history record, but the 998 is clean and was just serviced recently with a new fuel pump put in since it wasn't starting. He says it runs great now. I have factored in the 12k service belts etc.. I figured the 998 will be cheaper to service since it has the testastretta.
Human Verification
Ducati 998 / 999 IAW59M Canbus Stenley Tech Forum 9 Dec 5th, 2016 3:36 am
What Wheels Fit a 998 rl204 Superbikes 3 Nov 9th, 2016 10:45 am
Upgradinr my radiator on the 998 gary856 Superbikes 11 Oct 23rd, 2016 10:50 am
998 buil on 996 Frame, any experience? duplo Tech Forum 8 Jun 9th, 2016 4:39 pm
Leftover 748, 998 parts, motors, frame, etc. Artistimo Parts and Accessories 6 May 19th, 2016 7:02 pm
