Engine Ice - Ducati.ms - The Ultimate Ducati Forum
  • 1 Post By Ghwallice
  • 1 Post By Namor
post #1 of 10 (permalink) Old Jan 9th, 2017, 3:17 pm Thread Starter
Engine Ice
I run "Engine Ice" in my little turbocharged KTM SMC 690 and it works a treat keeping the temp down.
I also want to use it in the 916 and 999, and don't see why it should be an issue, but thought I would check on the forum first.
Any reason I should not use "Engine Ice"?
Regards, Greg
Radioviator likes this.
Ghwallice is offline
post #2 of 10 (permalink) Old Jan 9th, 2017, 3:56 pm
Thumper580's Avatar
I used it in my 996 in the hot summer.... Couldn't really tell a big difference with temp reduction. Maybe it has other properties that make it desirable. I saw no negative affects.
Thumper580 is online now
post #3 of 10 (permalink) Old Jan 9th, 2017, 5:16 pm
Namor's Avatar
No problems. Use it all you like.
Please give me a picture of the turbo and the SMC. Really, how can it be ridden safely? I want it.
Was the turbo a "direct" fit? Or did internals have to be changed?
I use Waterwetter on my bike. There is a difference. It is slower to heat up, temps are stable longer, but I am still at 210 at the track. It manages the temperatures better, but doesn't run much cooler.
97 916/996 "The Time Machine"
Namor is offline
post #4 of 10 (permalink) Old Jan 9th, 2017, 5:56 pm
gary856's Avatar
need a bigger radiator
You can never have too many motorcycles, no matter what the wife says!!!!
2002 998 custom, 1999 996 track bike, Future 999, 998 hybrid project!
gary856 is offline
post #5 of 10 (permalink) Old Jan 9th, 2017, 6:12 pm
kdehkordi's Avatar
fyi; engine oil that is too low a temp will not protect the engine as well as a "up to temp" oil.
kinda like the three little bears story; not too hot, not too cold but just right...
When in doubt, lean more...
02 SS750 Lovely first bike Red (sold)
02 St4s Rip 11/18/11 -- running now Matte Grey (sold)
03 St4s Restored from salvage Senna (sold)
10 Multi S 3yr and 55k mi Black
12 RSV4 F 15k mi
kdehkordi is offline
post #6 of 10 (permalink) Old Jan 9th, 2017, 9:25 pm
Namor's Avatar
I am not on board with that. Unless the bike sits at 240 while running, I see no problem. When I pit the temps immediately climb to 240 if I leave the bike running for a couple of minutes. I've never had a problem with the OEM cooling system doing a job cooling.
I've spent a great amount of time in Florida, summers and the "winters," and Texas temps are the same, or worse. Houston's humidity is on par with anything in Florida. 100+ during the summers.
Back to OP, would you PM me or post details about the SMC?
xracer likes this.
Namor is offline
post #7 of 10 (permalink) Old Jan 10th, 2017, 4:47 am Thread Starter
[QUOTE=Namor;6184889]
QUOTE]
Turbo is up under the seat. Everyone thinks it would a handful to ride but it's not. Interestingly enough it's turned a peaky wild child into a powerful tractor. It's a big turbo and doesn't spin up or down quick which limits it to some extent. It's probably much the same as a fully worked KTM 690 motor.
Awesome on a track. Starts tearing the rubber of the back tyre from about 2500rpm out of corners...
ID:	781297   Click image for larger version
ID:	781305   Click image for larger version
ID:	781313   Click image for larger version
ID:	781321   Click image for larger version
post #8 of 10 (permalink) Old Jan 10th, 2017, 5:37 pm
johnnie27's Avatar
Totally awesome thanks for sharing
Sent from Motorcycle.com Free App
YR1991 SUZUKI GSXR 750 YR2000 DUCATI 996 SPS YR2005 DUCATI 999R
johnnie27 is offline
post #9 of 10 (permalink) Old Jan 11th, 2017, 12:32 am
NO.NO.NO. You have enough bikes Jonny. I know what's going on in that brain of yours
xracer is online now
post #10 of 10 (permalink) Old Jan 11th, 2017, 1:46 am Thread Starter
I would strongly suggest you do not try it. The bloke that did the turbo install is a fkn genius when it comes to fitting turbos. He started at 15 years old and is now 39, and turbos is all he does. And then he did some engineering degree. He did the turbo on the KTM for a long term mate of his, but his mate did the norm, met girl, got married, sold the bike.
The next bloke rode it, but decided to get the motor rebuilt, hence needed setting up on the dyno again. He spent some months (and $2500au) trying to get it run again with a dyno bloke here in Brisbane that has a reputation for tuning turbo bikes. End result was the bike was basically not rideable.
I picked it for $5Kau, and drove 2000klm round trip to the bloke that originally built it to get it tuned. He was pissed off because his mate had sold it. He told me "It's a $10,000 plus turbo job". He got it to run pretty bloody good.
He was at the time putting a 1500hp turbo on a Toyota Landcruiser, tuning a Turbo Polaris that he had put a bigger turbo on for the Finx desert rally, had 2 of 620? Husaburgs on the go, and a ZX1400...
We had it up to 118hp at the rear wheel, but it was all critical edge, engine knock, pre-ignition, unpredictable throttle response. Not bad considered prior to the turbo it was 47hp at the rear wheel. We backed it all off and settled for 91hp longevity and controllability.
When you look at the map, there is no flow or continuity. May as well be a picture of some mountain ranges somewhere.
So much great fun! Road bike, track bike, daily ride to the pub bike.
Regards, Greg
Human Verification
2002 ST4s 996 engine - complete, assembled and running steve__d Parts and Accessories 8 Nov 22nd, 2016 11:04 am
FS: Engine Ice CookieMonster Parts and Accessories 1 Oct 31st, 2016 2:43 pm
Air Filters - Stock vs Aftermarket, and Airbox Resonance JEC Hall of Wisdom 10 Sep 10th, 2016 7:33 am
848 Evo Engine Question Dayon Superbikes 10 Aug 25th, 2016 6:46 am
Painting DOHC engine (S4) jooosstjee Tech Forum 2 May 30th, 2016 8:45 am
