Cam degreeing and valve adjustment - Ducati.ms - The Ultimate Ducati Forum
Graves Motorsports
Old Apr 15th, 2009, 9:38 am   #1 (permalink)
ducdom's Avatar
Hi
A question for all of you mechanics and techs.
Will a cam degreeing throw off my valve adjustment? In other words if I adjust my valve clearances and afterwards have the cam degreeing done ( I assume some adjustment is needed), will I need to readjust the valve clearances again?
Thanks for your info
Dom
2004 ST4s (sold)
2004 999 (sold)
2010 1198s (sold)
2011 GSX-R 750 / 2012 1199
ducdom is offline   Reply With Quote
Old Apr 15th, 2009, 9:46 am   #2 (permalink)
NoMAD's Avatar
Images: 3
I'm no tech, but here's my $.02
The valve clearance adjustment is setting the amount of free-play between the rocker and the valve.
The degreeing is changing when the valves open.
The two should not affect one another.
NoMAD is offline   Reply With Quote
Old Apr 15th, 2009, 9:51 am   #3 (permalink)
ducdom's Avatar
Now that I think about it it makes sense. Degreeing may change when the cam lobe hits the rocker with regards to the piston position but doesn't change how close the rockers are to the shim. So degreeing should not affect the shim clearances. It's fun to use the brain.
2004 ST4s (sold)
2004 999 (sold)
2010 1198s (sold)
Old Apr 15th, 2009, 10:21 am   #4 (permalink)
Banned
Images: 15
It surely won't make any difference in terms of your clearances. All it does is actuate the valves at a different time. Now if you were to CHANGE cam's entirely, yes... that could change your clearances.
Cam timing is worth the money, but unless your racing the bike, just have the mechanic set them to Ducati factory spec. When you start getting into more aggressive timing changes, the bike won't idle very well or it could loose some top-end.
tye1138 is offline   Reply With Quote
Old Apr 15th, 2009, 10:46 am   #5 (permalink)
ducdom's Avatar
Smile
Thanks for clearing this up for me.
Love this message board.
2004 ST4s (sold)
2004 999 (sold)
2010 1198s (sold)
Old Apr 15th, 2009, 10:50 am   #6 (permalink)
Shez748's Avatar
Images: 28
I've read that many bikes aren't close to factory spec. And once you have the cams degreed to factory specs the bike runs smoother and is much more responsive to throttle. If I can dig up enough info on how to do it i'll be degreeing my cams at the next valve check.
David
Ducati 2001 748S
Shez748 is offline   Reply With Quote
Old Apr 15th, 2009, 11:12 am   #7 (permalink)
Banned
Images: 15
The timing is done at the factory, very quickly. I'm also not quite sure if they time the cams in the bikes, or just have sets of cams that are pre-timed.
Needless to say, your right, the timing from the factory is less then stellar. But the timing in the service manuals is spot on. Its actually really easy to time the testastretta's, all you need are the proper gauges and some time to pull the bike apart.
Old Apr 15th, 2009, 11:22 am   #8 (permalink)
Tye, what do you think about setting the timing/degreeing cams on my 998 at the tech class? Are you up to that?
Flash
flash1034 is offline   Reply With Quote
Old Apr 15th, 2009, 12:27 pm   #9 (permalink)
Banned
Images: 15
I don't got the tools sadly, they're VERY expensive. I've been trained on how to do it, so if you wanna buy the tools, bring them along and we can do it... but its a grand to buy the proper ones. I could half-ass some home-made tools, but I'd need a mill and thats something I don't have.
I think Tom was working on a jig to adapt standard gauges for doing timing. If he ever finishes, I'd love to get my hands on it. Wink-Wink, nudge-nudge
Old Apr 15th, 2009, 12:54 pm   #10 (permalink)
Senior Misfit
TomTom's Avatar
Tye, the jig has been ready for a while now.
It does not fully follow the angle of the valve and may upset someone, but if you are using centerlines it will work just perfect. The upside is that you dont have to remove the airbox, and that is one thing you dont want to do on the 999 for example.
TomTom is online now   Reply With Quote
Cam Timing, Degreeing the Cam BillyD HyperMotard 10 Dec 24th, 2007 6:52 pm
Desmo valve system,, Is it out dated?? AzThumper Ducati Motorcycle Chat 173 Jul 5th, 2007 11:55 am
