999 fuel filter hose clamps - Ducati.ms - The Ultimate Ducati Forum
SportbikeTrackGearMotorcycle.com Classifieds!Motorcycle.com
Old Nov 2nd, 2008, 8:57 pm   #1 (permalink)
I am in the process of replacing the fuel filter and realize that the clamps on the hoses connected to the filter are not reusable. Do I need to get the Duc ones or are there other ones I can use? Thanks
cuvi is offline   Reply With Quote
Old Nov 2nd, 2008, 10:26 pm   #2 (permalink)
ZDM
Super Senior Poster
I just replaced mine on my 2003 999. I used the simple band type clamps where you just tighten the screw to adjust the clamping force. The fricken' name escapes me right now, they'll do fine.
ZDM is offline   Reply With Quote
Old Nov 3rd, 2008, 8:33 am   #3 (permalink)
kaos's Avatar
you should keep the oem style clamps,they are reuseable. the worm style clamps have been known to give issues on the harder fuelpump lines
giallo 949- impractical,irrational,irresistible ,13 txt pro 280,11-12 gasgas cervantes 250- all in all ,my version of garage nirvana
kaos is offline   Reply With Quote
Old Nov 3rd, 2008, 8:41 pm   #4 (permalink)
I put two of the regular hose clamps on but havent finish installing the assembly, waiting on the shop to open to get a o ring. How do you reuse the OEM ones?
Old Nov 4th, 2008, 12:29 am   #5 (permalink)
SAC
SAC's Avatar
Factory ones are unreliable. I had to switch to worm/screw types.
05 999: Heinz... I mean Termi 57mm & DP filters, ergal rollers, stripped emmisions, Nemesis ecu, Nichols flywheel, full Ohlin's around, DP slipper, Evoluzione slave, +3 ergal 520 , Cyclecat GP rearsets, and counting...
SAC is offline   Reply With Quote
Old Nov 4th, 2008, 8:31 am   #6 (permalink)
kaos's Avatar
only when someone doesn't install them right.think about it,why would ducati use these ''specialty''clamps inside the tank in the first place,and worm clamps elsewhere.there is a correct pliers for these clamps too
Old Jul 16th, 2009, 8:07 pm   #7 (permalink)
TheNibbler's Avatar
Images: 140
OK, so how do I remove those "specialty" clamps, and put 'em back on?
I hate working with fuel lines
'07 'nelli TnT Sport
'00 ape RS250
TheNibbler is offline   Reply With Quote
Old Jul 16th, 2009, 10:55 pm   #8 (permalink)
ZDM
Super Senior Poster
These special fuel line clamps are NOT reuseable. You will have to get new ones from a parts source or Ducati, Italy. A special clamping plier is used to squeeze them tight.....heck w/ that...I just used the wormy ones-figured I'll replace the fuel filter in a year or two and I highly doubt they'll do any harm to the line till then.
The Ducati clamps are $4 ea. plus the cost of the special pliers!
Old Jul 16th, 2009, 11:23 pm   #9 (permalink)
I just looked real quick, but this link (just as a reference) has some that are better then the “Worm” type. Worm clamps are not as strong and also tend to cut the hose -- usually won’t let you tighten them “enough” (for fuel injection hose) before skipping out of the groove and stripping -- not really made for fuel injection hose that is stiffer and or thicker to withstand the higher pressures so the clamp needs to be stronger. I’ve used this style that should be available at a local auto parts store -- The screw and nut aren’t of the best quality usually (Made in Taiwan crap) but still better then worn style hose clamps IMO.
Effort = Results
Out of Aluminum Fuel sender nuts - Thanks to all http://www.ducati.ms/forums/showthre...t=65886&page=2
yellow blur is offline   Reply With Quote
Old Jul 17th, 2009, 7:54 am   #10 (permalink)
94CobraR's Avatar
Images: 5
Check Desmotimes for clamps and tools...
Jimmy
Go Gators
www.g8rduc.com
94CobraR is offline   Reply With Quote
Fuel filter change 999 ZDM Superbikes 11 Nov 6th, 2008 6:02 pm
D16RR - Fuel OverFlow - FYI ! RD16RR Superbikes 24 Jun 8th, 2008 1:21 pm
Carby Fuel Filter & Key Xref Trout Supersport 3 Apr 4th, 2008 1:02 am
SSie Fuel Filter JDuc Supersport 33 Jun 8th, 2006 6:34 am
Fuel Filter ST4s Question alexfischer Apparel and Accessory Chat 9 Apr 29th, 2006 2:01 pm
